Old 04-17-2004, 01:57 AM   #1
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
Default Progressive Boost Map for Newb UTEC Tuners - ver 4.2 OLF only
Here is what I came up with to replace the non-existent boost map in the TXS stg1 base map. The base map gave me jerky transition from ECU to UTEC and some pretty serious knock once I got the boost dialed in to a reasonable level. I use this boost map with 2-turns on the ABC and it gives me 16psi peak boost. I have OLF transition set to 35%. This map has pretty well eliminated the jerky transition and so far (knock on wood) there is no knock.
Feel free to try this map, and if it works for you, use it forever in good health. No royalties, fees, or any other strings are attached. Here's hoping the formatting is readable after I cut and paste...
Boost Map
[0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0]
[0] [0] [0] [200] [200] [200] [200] [200] [200] [200] [200]
[0] [0] [0] [200] [200] [200] [200] [225] [225] [225] [225]
[0] [0] [0] [200] [200] [200] [225] [250] [250] [250] [250]
[0] [0] [0] [225] [225] [225] [250] [275] [275] [300] [300]
[0] [0] [0] [225] [225] [250] [275] [300] [325] [350] [350]
[0] [0] [0] [225] [250] [275] [300] [325] [350] [400] [400]
[0] [0] [0] [250] [275] [300] [325] [350] [375] [400] [400]
[0] [0] [0] [250] [275] [300] [325] [350] [375] [375] [375]
[0] [0] [0] [250] [275] [300] [325] [350] [350] [350] [350]
[0] [0] [0] [250] [250] [275] [300] [325] [325] [325] [325]
[0] [0] [0] [250] [250] [250] [275] [300] [300] [300] [300]
[0] [0] [0] [250] [250] [250] [250] [275] [275] [275] [275]
[0] [0] [0] [250] [250] [250] [250] [250] [250] [250] [250]
PS. Be sure to double check your peak boost and scale it accordingly to achieve your target and not over-boost. Special thanks to the creator of the "Utecedit" application. I couldn't have done without it! It's available for d/l over at wrxhackers.com
Blennophobic is offline   Reply With Quote
Old 04-17-2004, 03:11 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
you can feel free to put higher CLB numbers in the low rpm sites - that will help (ever so slightly) to bring boost up fast when you're starting at low rpms.... I think putting whatever your max CLB number is would be fine all the way down to 0rpm
nhluhr is offline   Reply With Quote
Old 04-17-2004, 03:40 AM   #3
hippy
Member#: 36528
2002 Impreza Wrx
yeh, I don't think the jerkin problem is with the boost map(could be wrong).....
Old 04-17-2004, 01:10 PM   #4
Blennophobic
Member#: 25886
2003 WRX Rally Blue
I forgot to mention that I consider this a conservative boost ramp which would sacrifice some low-end torque. My primary goal was to smooth the UTEC transition which I think worked out pretty well. It loses a bit of the torque kick, but I think it`s a good starting point for newb stage 1 tuners.
Old 04-17-2004, 02:46 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
Conservative ramp? Why do you have lower numbers in lower rpm points of the same column? Do you really think that's a good boost map for new tuners? Closed loop boost is not like open loop. If you want a conservative spool, set the gain higher. You can have the same boost number all the way down one column from 500rpm to whatever rpm you want the boost to start ramping down.......
peace
Old 04-17-2004, 05:17 PM   #6
Blennophobic
Member#: 25886
2003 WRX Rally Blue
I don't follow your logic. Why would anyone want the same CLB target at 2000 rpm as at 3500? Since it's a target, I might as well set it to something realistic. Given the turbo doesn't produce as much boost down low, you can get away with the same numbers in the lower rows, but my point is I found this map to help a lot in reducing the effect of the rough cross-over... why don't you give it a try and let us know how it goes?
Old 04-17-2004, 09:10 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
Because the utec will ramp the boost up quicker when it's farther away from the target boost. If you want a target boost at a given tps, then you can put that number down the whole column. The ramping of numbers upward from low to high rpms is not normal. It will only change how the turbo spools at low rpms. Changing the gain will change how the turbo ramps at any rpm. No offense, but I don't need to try your map to see what it will do. On the same note, I have a totally different setup from you, so yadayadayada. If I were you, I'd raise the numbers in the lower rpm points......
peace
FS: UTEC WRX 2003 ECU ver 4.2 edkwon Tri-State Area Private Classifieds 7 10-30-2006 05:02 PM
FS: UTEC WRX 2003 ECU ver 4.2 edkwon Engine/Power/Exhaust 1 10-07-2006 03:54 AM
need stage 3 ver 4.2 map ASAP gotawd UTEC 1 06-04-2006 02:08 AM
NY: UTEC rev 6b ver 4.2 hellafastwrx Private 'For Sale' Classifieds 20 11-28-2005 02:34 PM
Less MPG since addition of Utec rev. 4.2 OLF. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-02-2005 12:39 AM
