Vancouver Impreza Club
Old 04-17-2004, 05:28 AM   #1
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
Default 02 sensor help please
does any one have any tips on taking the 02 sensor out of the downpipe? the sensor seems to be stuck (seized) and it wont come out. seems that if i force it out the threads may tear or the sensor may get damaged.
if its not possible to get it out then how much would a new one cost?
i guess the only place to buy one is from the dealer?
JikJak is offline   Reply With Quote
Old 04-17-2004, 05:53 AM   #2
Happy_Days
Member#: 35049
2013 Nissan GTR
Super Silver
Try using wd40 or other bolt loseners. (spray and let it sit for a few mins)
Besides trying with an adjustible wrench, you can actually purchase a socket wrench for the 02 sensor, just to be safe.
You definately don't want to strip the threads on it, and when you successfully get it off.. be sure to pre-twist the O2 sensor cable counterclockwise so it doesn't stay twisted up from being re-tightened back on your downpipe.
You have my number if you need help.
Happy_Days is offline   Reply With Quote
Old 04-17-2004, 06:17 AM   #3
aawen
Member#: 27167
2015 FXT
You can get it from Subaruparts.com
It's 114.26 us +shipping.
I believe dealer here selling around 270 cdn
Last time called dealer and asked about o2 sensor for uppipe, around 240+tax
aawen is offline   Reply With Quote
Old 04-17-2004, 01:22 PM   #4
Avenger
Member#: 1234
Do not use WD40 or any other lub that is not sensor safe on the 02 sensor unless you are not going to reuse the sensor. WD40 can harm the o2 sensor. Use a o2 sensor socket to remove it.
Avenger is offline   Reply With Quote
Old 04-17-2004, 01:34 PM   #5
Happy_Days
Member#: 35049
2013 Nissan GTR
Super Silver
I disagree, it's harmless and when you spray it, the sensor is actually still inside the downpipe.
This isn't like the gunk from k&n filters getting stuck on the maf.
Old 04-17-2004, 07:26 PM   #6
Avenger
Member#: 1234
When you spray it on the sensor and when it is removed some of it can get onto the sensor tip. Plus WD40 have silicon in it and it floats in the air. The o2 sensor takes reading at the tip and the outside of the sensor to compair the oxygen content. The amount of oxygen different is equal to the voltage output. Silicon will affect the o2 output.
crank/cam sensor HELP PLEASE 199subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-15-2008 05:59 AM
EA82T code 11 crank angle sensor help please!!! iluvdrt Pre-2002 Factory Turbo Powertrain 4 11-02-2005 06:25 PM
02 sensor help please JikJak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2004 06:53 PM
02 Sensor Help Please!! 1DOWNCLOWN Electrical & Lighting 8 02-14-2004 05:55 PM
02 sensor question please help ac_gohan Normally Aspirated Powertrain 1 02-04-2001 09:59 PM
