Old 04-17-2004, 04:29 AM   #1
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
Default 02 sensor help please
does any one have any tips on taking the 02 sensor out of the downpipe? the sensor seems to be stuck (seized) and it wont come out. seems that if i force it out the threads may tear or the sensor may get damaged.
if its not possible to get it out then how much would a new one cost?
i guess the only place to buy one is from the dealer?
JikJak is offline   Reply With Quote
Old 04-17-2004, 07:58 AM   #2
Aegon
Member#: 42435
You can get an 02 sensor wrench at most hardware stores. It is a deep socket with a slit cut in the side so that the wire can fit through. These wrenches will wrap all the way around the sensor and provide the tightest grip so you can push as hard as necessary without worrying about breaking anything. Our O2 sensors are 22mm (edited as pointed out by Subiestyle).
If the threads are damaged I'm not sure what can be done about replacement or cost.
Hope this helps and good luck.
Aegon is offline   Reply With Quote
Old 04-17-2004, 11:55 AM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
Just to add. . .a new sensor costs around $150. You should be able to get them from the dealer. If not, then try www.subaruparts.com
Calvin
cnk is offline   Reply With Quote
Old 04-17-2004, 02:11 PM   #4
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
Actually the o2 sensors are 22mm or 7/8. also if you don't want to buy one of those sockets, just unplug the sensor (which you should do anyways), then just slide the closed end of the wrench through the wire & down to the sensor. BTW i've used this method for the front & rear o2 sensors. I've done 5 U.P./ D.P. installs so far & I've been able to get the job done w/ this method. Hope this helps.
SubieStyle is offline   Reply With Quote
Old 07-23-2004, 05:53 PM   #5
Smoke Show
Member#: 25129
2003 wrx stg4++
kills:4trny,mtr,trbo,clth
man i have a o2 sensor socket and a huge ass breaker bar on it and i still just rounded hte sensor...
it sucks but whatever...
Smoke Show is offline   Reply With Quote
crank/cam sensor HELP PLEASE 199subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-15-2008 04:59 AM
EA82T code 11 crank angle sensor help please!!! iluvdrt Pre-2002 Factory Turbo Powertrain 4 11-02-2005 05:25 PM
02 sensor help please JikJak Vancouver Impreza Club Forum -- VIC 5 04-17-2004 06:26 PM
02 Sensor Help Please!! 1DOWNCLOWN Electrical & Lighting 8 02-14-2004 04:55 PM
02 sensor question please help ac_gohan Normally Aspirated Powertrain 1 02-04-2001 08:59 PM
