Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-17-2004, 10:28 AM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Another Resonator Question
I recently installed an MRT headerback exhaust (equal length headers, 2.25" midpipe, hi fow cat, MRT muffler) and it's kind of loud. I called the muffler shop about installing a resonator and they told me they had a secondary muffler they could weld into the system. My midpipe is 2.25" piping. What is the least restrictive way to quiet my exhaust down. Is there something else I should buy and have the shop weld in?
whtlegacy is offline   Reply With Quote
Old 04-17-2004, 11:23 AM   #2
Skylab
Member#: 4263
Magnaflow resonator.
Worked like a charm on my RS.
Skylab is offline   Reply With Quote
Old 04-17-2004, 11:35 AM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
where did you get yours? what is the difference between a resonator/glass pack/second muffler?
Old 04-17-2004, 11:38 AM   #4
Section 8
Member#: 821
Make sure anything that you put in your exhaust has a perferated core and NOT a louvered core.
Glass packs also work. They do not last quite as long, but they are REALLY cheap. THe longer the glass pack, the lower the tine is going to be. THe shorter it is, the less expensive (they are all likely going to be around 10$ of each other).
If you want to quiet down a little, get the 2.5" core resonators/glass packs. These will be best for performance. If it needs to be seriously tamed, go with a 2.0" core. It is some times hard to come buy 2.25" cores, but those would be optimum.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 04-17-2004, 11:45 AM   #5
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
ok so glass packs are cheap, don't last very long, and are not very restrictive. the muffler shop says they have glass packs in stock. what should i look for? is a longer or a shorter one better?
by core resonator/glass pack do you mean a combination of the two? where would I get one of these?
Old 04-17-2004, 03:24 PM   #6
Section 8
Member#: 821
The "core" is the diameter of pipe running through the item of interest (glass pack/resonator). For instance, Thrush produces glass packs with multiple diameter "bushings" (these are the short pipes sticking out the end of the glass pack, they can be expanded for slip fitting them, so are called "bushings". I don't know why.) but the diameter of the core can still be 2 inches, so the size gets smaller in the glass pack then gets larger at the exit. Ideally, you want to get a 2.25 diameter from end to end, but they don't make the core that diameter.
Here is a PDF that has all of the Thrush glass packs.
Thrush
You will see that there is either 2 inch or 2.5 inch "tube" sizes. THe tube is the core through the middle of the glass pack.
To quiet your muffler, a 2 inch core glass pack would do it well. THe 2.5 would mellow it out a bit, but not as much as the 2 inch.
If you muffler is just to loud, go with a 2 inch "tube" diameter, if it makes a sound that is head splitting, but the volume actually isn't that loud (people can't hear you coming from 5 blocks away) go with the 2.5 inch.
THe longer glass pack you get, the lower the tone. THis will give the "illusion" of lower volume because the noise isn't so piercing, due to the higher frequencies being dampened by the fiberglass packing.
I would recommend the 24201 or the 24211. I would go with the 24211 unless the muffler is just simply way to loud.
I don't know much about any other brand of glass pack. I know that Purple Hornies have louvered cores, so you need to stay away from those. Some other "generic" brand also has a louvered core, that alot of muffler shops all have. Stay away from anything that has a louvered core.
Old 04-17-2004, 08:02 PM   #7
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
24211 looks good. I'll probably order it soon. You don't think a 4" total body diameter might cause any fitment issues?
Old 04-17-2004, 10:52 PM   #8
Section 8
Member#: 821
It might, but it shouldn't be a problem for a muffler shop. Moving a hanger or two is pretty easy.
cheeRS,
Greg
Old 04-18-2004, 04:37 PM   #9
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
The Thrush Glasspack will last about 6 months before you blow the fiberglass packing out. Been there, done that, go for something of better quality (Magnaflow). When I first installed the Thrush it was nice a quiet, after about 8 months I had the whole cat-back removed and replaced everything with 2.00," no resonators, stock muffler.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 04-19-2004, 03:48 PM   #10
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I went ahead and ordered the Thrush glasspack for less than $35. It's cheap, and I'm not going to sweat longevity at the moment. What do I do with it? Do I weld it into the midpipe? The spec sheet says it is 35" long.
Old 04-19-2004, 03:51 PM   #11
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
I had mine welded in right after the 2nd Cat.
-Charles-
Old 04-19-2004, 03:54 PM   #12
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I only have the one cat just after my headers. How long is an Impreza midpipe? I know the Legacy midpipe is 3.5" longer. I just hope it's more than 35" long so I can accomadate the resonator without welding on the intermediate pipe/muffler.
Old 04-19-2004, 04:13 PM   #13
Section 8
Member#: 821
Have them do what they need to, to install it with a slip fit and clamps. THis way you can just remove the old one, and put a new one in should the time come (you think that it is too loud again, they still work somewhat when they are "old" when not a primary source of sound suppresion).
I had mine built in this fashion, for the same reason.
cheeRS,
Greg
Old 04-19-2004, 04:15 PM   #14
Section 8
Member#: 821
Oh, and it will go in the straightest portion of pipe in the midpipe.
cheeRS,
Greg
Another Resonator ?? MyRuRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-07-2008 01:37 PM
Resonator question...just a quicky obyone Normally Aspirated Powertrain 23 05-08-2003 07:46 AM
Removal of stock muffler, keeping the resonator? Question. BlueDemon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-17-2001 07:44 PM
Apex resonator question watcher in the sky Normally Aspirated Powertrain 2 12-15-2001 03:03 PM
Resonator Question, simple one... BrysImpreza Normally Aspirated Powertrain 2 05-28-2001 10:36 AM
