Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Old 04-17-2004, 01:02 PM   #1
BIGSKYWRX
Member#: 7958
09 GH B+
Default Hella FF1000 questions and opinions needed
I've looked into these lights and they appear to be a very good deal economically ~ $110 for the kit. These would be combined w/ HID Morette's and mounted centrally on a light bar.
I was thinking 100 watt vs 55- do you need to do anyting different w/ the setup going to 100 watt?
These would be utilized for fast gravel night runs (and critter avoidment as well).
My fog lamps are removed for brake ducting and I'd like to (if posssible) run the 1000's at the oem switch. I'd like to have them run as on/off regardless of high beam/low beam- is this possible w/ the oem switch? Also is it possible to come up w/ a plug/play setup utilzin the fog plugs on the 1000's? It appears there is enough wire to run them to the location I want.
The other lamps I was looking at was the 4000's- I'd rather go w/ a 7' lamp than a 9" if possible, so any opinions on the 1000's would be much appreciated.
Sorry for the scattered quesstions.
TIA
Big Sky
Old 04-17-2004, 10:52 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
here is how to use the factory switch. i use it on my hella 500s with all upgraded wireing too.
PARANOID56 is offline   Reply With Quote
Old 04-17-2004, 11:00 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
Thanks. Does this allow simple on/off operation of your 500's or are they tied into your low beams like oem?
Did you replace w/ heavier gauge wiring?
Big Sky
Old 04-18-2004, 12:03 AM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
yes, this will work compleatly seperate then the headlights. as i hate how its all tied together. and i did a heavy duity harness with 12ga wire, and a relay in the engine bay.
and then wraped the thing in braded covering. very nice
Shane
Old 04-18-2004, 10:52 AM   #5
BIGSKYWRX
Member#: 7958
09 GH B+
Super! Thanks.
Mike
Apple computer question and opinion. wrx2.0 555 South East Region Forum 37 06-11-2005 12:39 AM
questions and opinions?!?! djplayboy Factory 2.0L Turbo Powertrain 5 04-12-2005 07:09 PM
Tire size questions - all opinions needed AWDrifter21 Tire & Wheel 2 04-04-2005 04:43 PM
Warranty Questions and Opinions about a funny situation sub25rs Warranty Issues & SOA Problems 9 01-15-2002 08:39 PM
Questions and opinions needed, please. MattJP Technical Forum Archive 4 07-31-2000 06:42 PM
