Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 04-17-2004, 04:01 PM   #1
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Default UTEC Checksum errors!
Help!!! I've recently flashed to the 4.2 firmware, and now I get checksum errors whenever I try to upload my maps! any of them!
I've tried even making maps on the utec, saving them, and then uploading them! they get checksum errors too!
I reflashed to 4.1, and now it has the same problem. The maps are FINE, I checked them with UTECedit, no actual checksum errors!
Anyone have any ideas on what I can do?
TIA
GMTarkin is offline   Reply With Quote
Old 04-17-2004, 06:27 PM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
any issues w/ the toggle switches on the board Did you verify they're correctly set? Try reloading the firmware? Other than that I couldn't tell ya.
MustGoFast is offline   Reply With Quote
Old 04-17-2004, 06:59 PM   #3
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
the toggles are in their proper positions, i've reloaded the firmware several times, Today i finally decided to sit in my passeneger seat for about an hour and reload the 4.2 firmware, attempt to load the map, still a No-go. I then proceeded to manually copy the stg2 map into my UTEC, oh boy, let me tell you how much fun that was!
Old 04-18-2004, 01:12 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I believe the checksum errors are because any time the base map is altered, the checksum won't match and it will come up with that error.
AFAIK, all it means is that the map has been changed.
No huhu....
Uncle Scotty is online now   Reply With Quote
Old 04-18-2004, 02:40 PM   #5
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
You dont quite understand then I guess. My maps are 100% unaltered. They just woln't load
I've redownloaded the basemaps from txs.com, still no-go.
Old 04-18-2004, 04:06 PM   #6
Bolster
Member#: 22290
2002 WRB WRX Wagon
I thought this was a problem with hyperterminal, not UTEC. In the past when I've had this issue, I just bit the bullet and typed in my maps manually.
If you've installed a stage IV basemap from TXS using the same laptop or PC (even if it was a long time ago) then hypterminal will do this. The way to get around it is save your maps from UTEC to your PC under a different name. Then you load the new firmware and upload the map with its altered name.
Bolster is offline   Reply With Quote
Old 04-18-2004, 06:43 PM   #7
TurboXS (Pete)
Member#: 16704
Bit of a strange problem here.
If you can reflash the UTEC then this means that the serial port on the UTEC is working correctly.
Obviously you can communicate with the UTEC as you can get to the load map menu. This proves that the serial communication both to and from the UTEC is okay.
The map save and load routine on the UTEC has not been changed since Version 3.2 and is basically the same as the earlier versions so we know it is a working piece of code.
The problem you describe does still suggest either a setting problem with Hyperterminal or your PC.
1. Can you check that the flow control in the Hyperterminal settings is set to "none".
2. Can you try another PC?
I have tried to replicate your problem but the only time I get a checksum error at 7% loading is if I try to load the parameters map in a tuning map position.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 04-18-2004, 08:17 PM   #8
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
I'll try using someone elses laptop as soon as I get a chance...
I was thinking about it myself, I came up with the same ideas as you, there cant be anything wrong with the port, since reflash works perfectly. All utec functions work perfectly, except for loading maps. I've tried loading a parameters map, it does the same thing as a regular map. same error, same time.
Flow control is set to none. I'll try and get some elses laptop in a few..
Are there any other types of terminal software out there? like hyperterminal, that I could try?
Old 04-18-2004, 09:39 PM   #9
TurboXS (Pete)
Member#: 16704
We have used Tera Term although you use the "send file" option in the "file" menu for loading maps.
regards
Pete
(TurboXS)
Old 04-18-2004, 09:49 PM   #10
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Not sure if this will help...
I had a funky problem where my serial cable was kinked. It caused intermittent issues that were very difficult to diagnose. Types of errors included: checksum errors, gobbledygook on hyperterminal, wouldn't turn on. But the problems only surfaced a few times a month. I thought the UTEC or computer were messed up.
But when I pulled the cable out, it had a kink where I ran it through the dash. Replacing the cable eliminated all the problems.
T-WRX is offline   Reply With Quote
Old 04-19-2004, 01:25 AM   #11
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I just got my UTEC, and am having the same issue. Everything works, except loading a map. Flashed to 4.2...used all other functions...cant load maps.
I'm using a USB adapter, which I thought could be an issue, but all other aspects of the UTEC work as they should.
CKxx is offline   Reply With Quote
Old 04-19-2004, 10:30 AM   #12
CKxx
Member#: 33458
93 RX7+09 Forester
BUMP before is bury my fist in the dashboard.
Old 04-19-2004, 11:00 AM   #13
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
I'm going to give this a differant computer a try when my buddy gets back on campus in a little bit, as well as try this other terminal software.
I too am using a USB adapter, I'm going to reinstall those drivers too.
You could manually type the map in, But that's a big whore, be prepared to sit in the passengers seat for about 30 minutes doing that
I can say the new Stage 2 basemap is awesome though!!!
Old 04-19-2004, 05:34 PM   #14
rexxer
Member#: 27624
2014 WRX
USB adapter... hmmm... this sounds oddly like problems we've had at work. Make sure that the UTEC is properly and WELL grounded to some type of Earth ground/chasis ground. Unlike with PCs, when you are using a laptop, they don't have a proper earth ground. Even soldering a wire onto the the shielding on the serial cable and attaching the other end to a ground on your car might work.
rexxer is offline   Reply With Quote
Old 04-20-2004, 10:31 PM   #15
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Wink laptop errors
with the latest generations of laptops, the transfer speeds
actually exceeds what the hyperterminal can handle.
dumby it down and find/borrow something with less
than a p4 chip if you can.
We ran into the same thing loading 4.2 into a utec
a few weekends back.
Good luck
Ben
Jax Mod Squad
Old 04-20-2004, 11:10 PM   #16
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Well, you see, the adapter cable drivers tell you to select a speed, and the deal here is that it worked in the past, with 4.1, load up 4.2, no problems, try to load map, craps out, load 4.1 back up, try to load a map, it craps out too! when it worked before! on the same hardware!
Old 04-22-2004, 12:24 AM   #17
CKxx
Member#: 33458
93 RX7+09 Forester
BUMP- Im not lettin' this one fall off since there is no solution yet.
Old 04-22-2004, 11:10 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
has this problem occured with a TRUE serial port connection, not a faked out USB?
ken
Old 12-25-2004, 12:05 AM   #19
kool168
Member#: 61006
i have the USB adaptor too, same problem. couldn't load any maps to UTEC. and i deleted all my maps in the UTEC
kool168 is offline   Reply With Quote
Old 12-26-2004, 05:49 PM   #20
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
I have this exact same problem. I have a 2.8GHZ Toshiba laptop with the Frys USB adapter. I can load maps to 3.X but not to 4.2 Utecs. Its really begining to be a big problem for me. I can tune, log, download but I cannot upload maps.I have tried using our older Sony laptop and it has the same issue. I tried an IBM and a Dell both later models and they worked perfectly. The Dell would crap out "some" of the time on an upload. Its a real pain to have to borrow a laptop to load maps up so I can tune a car. I have tried changing every possible setting on the USB adapter and Serial port listing in the Device manager with NO luck. My uploads get to 16 or 18% and then fail. Something must have changed in the software or hardware on newer Utecs as this was never a problem before but now is. I have posted the model and brand of the USB adapter and many, many people use it. I might try a PCMCIA card to serial adapter next but hate to have to spend the money not knowing if this will fix the problem. Also my USB adapter worked perfectly wth the IBM and Dell laptops. If anyone has any suggestions please post.
Clark
AZScoobie is offline   Reply With Quote
Old 12-26-2004, 06:53 PM   #21
TheMadScientist
Member#: 23717
2005 Big red
Have you guys tried turning down the serial speed in the Utec and the USB adapter. I had an issue with I think firmware2.5 but only with the USB>serial adapter on one persons set up. I went to the slower setting in the Utec and USB adapter and it was fine.
TMS
TheMadScientist is offline   Reply With Quote
Old 12-26-2004, 11:50 PM   #22
CMJ
Member#: 39235
Just got a new 3ghz Toshiba and I'm using an IOGear usb adapter and have the same problems as AZScoobie. I can do everything but upload. The old 300mhz with real serial port has no problem uploading.
CMJ is offline   Reply With Quote
Old 12-28-2004, 06:38 AM   #23
r0nm4n
Member#: 34183
Same problem here: checksum error uploading maps using an IBM T40 laptop with usb to serial convertor. No issues when using an old HP 1Ghz Pentium III laptop with integrated serial port.
r0nm4n is offline   Reply With Quote
Old 12-28-2004, 02:54 PM   #24
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
I have the IO gear Adapter. So what are we to do here??? Obviously newer computers are using software serial ports and this the problem. TXS needs to jump on this ASAP as those old laptops are being replaced right. If we can use the Utec with a new laptop we are all in trouble. It sucks that I am going to have to go buy an Ebay laptop just to load maps.
I think we need to get a list of working newer laptops and adapters going so people can buy items that work. If yours works list it out for us...
Clark
Sony Vio 2GHZ with IO gear adapter - NO
Toshiba A65 2.8ghz with IO gear adapter - NO
Kingpin is offline   Reply With Quote
Old 12-30-2004, 03:28 PM   #25
rexxer
Member#: 27624
2014 WRX
The solution we found at work involved earth grounding both the laptop and the device (in this case a UTEC) to the same thing. Laptops are not properly grounded and the USB to serial convertor does not appear to be designed well enough.
HOW TO: UTEC map upload checksum error fix cdvma Engine Management & Tuning 11 11-27-2008 10:08 PM
UTIME Checksum Error bcblues UTEC 3 05-29-2006 12:31 PM
utec upload error sooshimon Engine Management & Tuning 21 09-22-2005 08:17 PM
Need Stg3 Utec map, with no checksum error coyote73176 Engine Management & Tuning 8 03-04-2005 01:02 PM
CMOS Checksum Error - Defaults Loaded Bigred14 Texas Impreza Club Forum -- TXIC 5 04-05-2002 12:04 PM
