Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-04-2000, 08:33 AM   #1
dada21
Member#: 383
2001 Outback Sport
Question 97 OBS Check Engine Light?
Hey all... I did a search for this subject, but unfortunately, a lot of the older topics with the check engine subject lines aren't available anymore
At 63350 miles two days ago, I started my car to find the CE light went on and stayed on. Thinking it was a loose gas cap, I went around to the side, and twisted it, and it had about a 1/3 revolution of play before it clicked -- possibly was the problem. Light didn't go off, so I was thinking I would try to see if checking the codes would clear it.
I found two wires under the dash [green connectors] that I attached, turned the car on, and the CE light blinked fast continously. I let it sit for about 2 minutes but it never slowed down or burped or stopped blinking!
When I unplugged the wires, the light was still there. Unfortunately, I don't have time to take the care to the shop until late next week. I'm trying not to drive it too much, but the car starts and drives fine, no problems from what I can see.
Any ideas? If a gas cap was loose, will putting it back on keep the CE light on still? One of my neighbors told me that a fast-blinking code on the light means real trouble, but he's not a scooby-head, so I basically didn't take his advice very strongly, but I do want to take the car in if someone here thinks it could be serious...
Thanks!
dada21 is offline
Old 05-05-2000, 11:48 AM   #2
dada21
Member#: 383
2001 Outback Sport
Post
Just wanted to get this back into the recent postings since people had trouble logging in to even read it for a few days Anyone have any ideas?
dada21 is offline
Old 05-11-2000, 12:48 AM   #3
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Lightbulb
The GREEN connections are for when the Diagnostic is hooked up. Otherwise not useful in this situation.
Next step is an ECU reset(just disconnect the negative battery terminal for about 20-30 minutes.
If the light persists, it's bad Gas!
Adam
97OBS
OBSS is offline
Old 05-11-2000, 12:52 AM   #4
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
You definately need to disconnect the test connectors. If it was a loose gas cap, the light will go off after a certain number of cycles of turing the engine on and off and may take a few days.
rao is offline
Old 05-14-2000, 06:00 PM   #5
T'impreza
Member#: 328
'97 Outback Sport
Sedona Red/Titanium
Lightbulb
Once upon a time there was a recall due to corroded oxygen sensor wiring under the hood scoop. Might be something to check. I never bothered to get mine fixed. Crossing my fingers. Probably takes about 3 years to go bad =) See the information below found at:
http://www.raindrop.com/subaru/problems.html#oxysensor
"97 RED ALERT!
Subaru of America, Inc, has determined that some 1997 model Subaru Impreza Outback Sport 2.2L vehicles may experience corrosion of the oxygen sensor wiring harness connector due to water drainage from the hood scoop air duct. Under this condition, your vehicles On-Board Diagnostic (OBD) system will illuminate the "CHECK ENGINE" light on the dash indicating the need for prompt corrective action by your Subaru dealer.
WHAT YOU SHOULD DO:
To prevent this condition, you should immediately contact your Subaru Dealer for an appointment to modify the hood scoop air duct and the oxygen sensor wiring harness connector at no cost to you. The approximate time to perform this repair is less than 40 minutes. However, it may be necessary for you to leave your vehicle the full day of your scheduled appointment to allow your dealer some flexibility in scheduling other customers. Should you have any questions regarding this, please contact your nearest Subaru Dealer or Subaru of America, Inc., at 1-800-782-2783 (1-800-SUBARU3). "
-Tim
T'impreza is offline
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light for 97 outback.... Sobelizard109 Legacy Forum 6 11-27-2002 04:16 PM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
Check Engine Light - 2002 OBS wheeljack Newbies & FAQs 4 05-16-2002 05:42 PM
