Old 04-17-2004, 06:04 PM   #1
skyliner33v
Member#: 2675
MY02 Wagon 350whp
Default Legacy EJ20G into 93 L FWD
I recently purchased an early 90's legacy turbo engine from a friend I have a few questions about getting it swapped into my 93 L FWD. It's the Air to Water intercooled version and the turbo says RHB52 on it. It is an longblock with all the accessories but the wiring harness has been cut leaving a mass of wires exposed and useless. Now for the questions:
How hard will the wiring be? I've been told that a standalone ecu like a tec2/3 would be easiest, but I was hoping for something a little cheaper. Any suggestions?
Would I be able to run this engine with my stock FWD tranny until I am able to afford an AWD tranny?
I'm also guessing that it would be good idea to upgrade my fuel pump as well? Any suggestions on an adequate pump for this motor?
Anything that I might be forgetting or I might need to get this running?
Thanks for the input,
jason p.
skyliner33v is offline   Reply With Quote
Old 04-17-2004, 06:42 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
http://forums.nasioc.com/forums/show...hreadid=535963
1. Wiring will suck no matter what. I am thinking that I will pull the whole bulkhead harness and use a USDM turbo legacy harness, including rewiring the engine...
2. You can use your tranny until you do an AWD conversion. Subaru's are like Legos.
3 Walbro 255l fuel pump runs less than $100 and drops right in
4. Get me the other numbers off the plate on your turbo and I will tell you what car it came out of. And what color is your intercooler?
Old 04-17-2004, 08:54 PM   #3
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default EJ20 into 93L
skyliner33v quote:
This is a relatively cheap and fun conversion if you like to do it yourself. This is the same project I completed two years ago and the car is very competative with the high dollar big boys. This weekend it ran a 1:36 at Streets of Willow where the top time of the day was 1:31 by a spiced up EVO. I was passing the stock STi cars, which is a common experience for this conversion project.
The turbo output fits the engine well. The stock injectors are 460cc, which comes from RC engineering testing. A stock Legacy turbo pump will do quite well also, but it is cheap enough to replace it with a walbro. BTW you will need a new tank when you go AWD. I have set redline at 7K and the turbo holds at 14 pounds all the way up. My IC never gets really hot, even under full race conditions.
Yes the wiring is difficult. But doable if you stick to it and have the manuals. Matter of fact, I made two engine harnesses myself, the first one for the stock Legacy turbo ECU. BTW, that harness could be yours if you need it.
The air water IC needs all the plumbing, pump, tank and so forth. But it keeps you very stealth and works well. I made all this stuff also so I am sure it works well.
I hope you have as much fun as I did. Good luck.
Mike McBride
MZM is offline   Reply With Quote
Old 04-17-2004, 09:57 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
mm.. the tec wiring took me ~6 hrs pretty easy
well not direclty .. the older cars don't have the same connector on the pump but its not that big of a deal
if you do decide to go tec 2 shoot me an email ill shoot you a map or two to try
Old 04-18-2004, 03:14 AM   #5
skyliner33v
Member#: 2675
MY02 Wagon 350whp
Thanks for the responses guys.
The intercooler is all black, and I'll get the numbers off the engine tomorrow.
And I have already done most of the AWD drive conversion with the AWD gastank and the rear diff just free spinning, no driveshaft. All parts came off a 97 impreza L.
This harness could be used on my motor with a stock USDM Legacy ecu? Can I use a USDM turbo legacy ECU on my car? And I forgot to mention that my friend says the engine is JDM, but I don't really know for sure, and I don't think he really knew either. Do you know where I could find these manuals?
About how much does a tec2 go for these days?
thanks
jason p.
Old 04-18-2004, 09:50 AM   #6
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default ej20g wiring
skyliner33v
yes. yes, turbo only(91-94). they will all be jdm if intercooled. yes. PM me off line if you need further info. luck.
Mike M
Old 04-18-2004, 12:36 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
re tec 2:
used ~1000
tec 3 much much cooler
2500
turbo only(91-94).
er you mean 89-94 right :P
Old 04-18-2004, 04:44 PM   #8
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default US Leg Turbo
No. US Legacy non-intercooled turbo was MY 91-94. EJ22 block @165 HP. Thats the ECU mentioned.
Mike M
Old 04-18-2004, 11:29 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ah yes but the jdm version was 89-94 ..
Old 04-18-2004, 11:47 PM   #10
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Oh Boy!
Jaxx ah yes but the jdm version was 89-94 ..
Hey Jaxx, we are in the........drum roll........US. He doesn't have a jdm ECU according to his first post. So where should he look? In the JDM for a 89-94 ECU or maybe here in the good ole' US of A for a 91-94? Just as a practical matter. Answer , Uhh...in Japan for a commonly available 1989 Legacy Turbo ECU! Uh huh.
But you get points for JDM Legacy trivial pursuit. I hope you have a sense of humor.
Mike McBride
Old 04-19-2004, 09:03 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
Well,
Black AWIC means it is a '92 or '93 engine. the '89-91's were silver. Let us know on the rest of the numbers off the turbo. You see, the RHB52 that MZM so kindly quoted in case I missed it the first time is just the compressor housing. VF-8's, VF-10's, VF-11's and VF-12's all used that housing. But what matters is which Exhaust housing and number of blades you got. In all likelihood it will be a VF-10, but you might have gotten lucky.
BTW,
I can get you a USDM Legacy Turbo ECU if you decide to go that route. Just shoot me a PM...
Old 04-20-2004, 04:50 AM   #12
skyliner33v
Member#: 2675
MY02 Wagon 350whp
The compressor housing has 9 blades on it. The only numbers that I could find stamped on the block were 17BB, 12122, Japan, 715 and EJ20 and all were found behind the alternator. Any other place I have to look?
I'll try and get some pics up soon.
PM'd you Matt.
jason p.
Old 04-20-2004, 11:22 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the more that i look and retype this chart i think the difference between the GT and RS motor is really not the turbo but the change in rist pin offset ... thus makeing the one of the two motors 8.5 to 1 and the other 8 to 1
Code:
                                                        GT              RS
The highest output PS/rpm                              200             220
Largest torque kg * m/rpm                             6000            6400
Turbine diameter (entrance / exit)               52.5/43.0       52.5/46.5
Compressor diameter (exit / entrance)             56.0/41.2      56.0/45.0
Largest supercharging pressure                     450mmHg        450mmHg
Intercept point                                     2400rpm        2800rpm
Feather root number                                      9              10
Piston type                                      Slit type           same
Piston gauge diameter (mm)                          91.965           same
Piston clearance (mm)                           0.01 - 0.03          same
Piston pin offset                                      1.75           1.0
Piston bearing system                         Full floating          same
Piston pin hole diameter (mm)                        Phi 23          same
Piston pin total length (mm)                             62          same
dam this chart took for evar top get straight
oh and
450 millimeter of mercury [0 C] = 8.70155 pound-force/square inch (PSI)
Old 04-20-2004, 04:44 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
Jaxx,
If that were the case, then why do all the AUS/NZ guys confirm my information that the RS manual tranny got the VF-8 and 220ps, and the auto and all the GT's (GT's are wagons and RS's are sedans for others reading who are confused ) got the VF-10.
Skyliner33V,
If you have 9 blades it is a VF-10, but I am guessing you are looking at the exhaust side since that is the side that would be open to view. Check on the silver side of the turbo under all the black intake plumbing. There is a plate riveted onto the housing. There will be three lines of numbers. Post those numbers...
Or, if the back of yours looks like that, it is from an auto and surely a VF-10...
Old 04-20-2004, 05:05 PM   #15
skyliner33v
Member#: 2675
MY02 Wagon 350whp
yah, mine looks like that one, it came from an automatic.
Old 04-20-2004, 05:16 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
like nah
yeah matt .. i think that it is both bigger turbo and differnt compression ratio
i had trouble befor trying to confirm weather it was 8 to 1 or 8.5 to 1 . now that i look at that sheet it makes sense that it is BOTH
Old 04-20-2004, 07:07 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
jaxx,
Where did you get that info? everything I have seen says that both engine are 8.5:1
BTW,
you have new e-mail w/tracking #...
Old 04-20-2004, 11:01 PM   #18
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well for one .. from spoonaugle's ej20 sheetsheet
and i believe that the impreza verions are all 8 to 1
it was very fuzzy
i gave up and quite worring about it
Old 04-21-2004, 06:43 PM   #19
Structure828
Member#: 50488
1999 GC8 ej20g!
I am in the process of a similar swap. A 1991 Jspec EJ20G from a Legacy RS turbo 2.0 (VF8)
The VF8 turbo is bigger then the vf10 and vf11 and about the same as the vf12 found on the australian and NZ liberty rs'.
The wiring will be a bitch no matter which way you do it. My mechanic was unable to do the wiring and he has had my car for a very long time. We are now having it flatbedded to Central Florida Turbo in Orlando to finish the wiring.
DO NOT wire the system using BOTH ecu's it will lead to trouble.
You can use the OBD1 and wire it or the OBD2 but internal mods are needed to start it off the OBD2.
between me and Matt Monsoon we have done more research and probobly have tripple the real info then anyone does on the boards reguarding Liberty and Legacy info.
You can also get info on the LibertyRS boards.
PM me or Matt if you have more questions.
Nice pics Matt...
And hopefully I will be posting pics of my car and the full swap process from start to finish within the next 2 or 3 weeks
Structure828 is offline   Reply With Quote
Old 04-21-2004, 07:02 PM   #20
Matt Monson
Member#: 832
99 2.5RS, '85 911
I don't know if I want that kind of credit. I have done my homework, but haven't even begun the wiring portion of the program. Guys like MZM and Jaxx have gotten their hands way dirtier than mine and I wouldn't for an instant discount their knowledge...
Old 04-21-2004, 07:42 PM   #21
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Oh yeah!
Structure828
Keep in mind my car runs. It will be in a fifteen stage trans-Mexico tarmac rally event this next weekend, not on a car hauler. But then what do I know. Heh-heh.
Mike M
PS Matts post just appeared. A humble guy on NASIOC, unheard off!
Old 04-21-2004, 09:56 PM   #22
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
now i remember why structure828 is on my ignore list
Old 04-22-2004, 05:32 AM   #23
skyliner33v
Member#: 2675
MY02 Wagon 350whp
Well, after much thought and debate, I have decided that I am going to go the aftermarket standalone ecu to wire up the motor. I figure that if I get the standalone, it will save me money and time in the long run as I plan on building a bigger and better motor for this car and I can perform the switch much easier this way. This motor was bought to pretty much satisfy my need for speed now as the 1.8L motor just wasn't cutting it.
So now I have more questions.
Which aftermarket ecu would be ideal for running this motor now, and a different motor later on? I have really only looked at the electromotive tec2 (used or new) and the tec3 (which I wish I could get but can't afford), and the haltech E6k or E6x. Are there any others worth considering? I've heard some pretty good things about the Link/LinkPlus ecu. I hope to spend only about $1000 to $1500(absolute max) for the ECU.
Also, my car is a 93 so I'm pretty sure I'm pre OBDII but not completely positive. Will this make the wiring any easier than an OBDII'd car?
Since I will be running a standalone, can I upgrade to a slightly larger turbo without any damage to the internal parts of the motor?
I've also heard that the heads on the older legacy turbo motors aren't very good to begin with tend to get worse with age so are there any other heads that I can swap with while the motor is out to improve efficiency/performance?
And here is a link to the differences in the EJ20 motors that I found on legacycentral and I wasn't sure if you guys have seen it or not but I thought it would be good to post as a reference.
http://homepages.ihug.co.nz/~1amiga/ej2o.htm
thanks again for all the info and help
jason p.
Old 04-22-2004, 11:23 AM   #24
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
cool chart save as...
how can the compression ratio be the same of the compression pressure is differnt
ok ok
#1 the tec 2 has been realitivly simple to use and install, i can help you out with maps too now you just have to find a used one
i am using the vishnu "pems" system the stock ecu controls some things and the tec others .. go to vishnus page and download the instalation instructions if your intersted. this will not create the same proublem that structure had with running 2 ecu's
#2 its not obd-2 your safe
#3 yes if you can find one - i have been looking for a good deal on a td05 for 18 months now
#4 its subjective they are better than the usdm legacy turbo heads (bad) but not any where near as good as the ej205 or 207 or spec C
#5 you have the second one
intersting differnt cams too
and colder spark plugs (than any other ej20) wonder if it would help to go to a "8" heat range and run more advance
Old 04-22-2004, 12:01 PM   #25
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Aftermarket ECU
skyliner33v
It is easier to use a aftermarket ECU because of the wiring and tuning requirements of the stock (US)ECU. But not easy. Remember you still need a harness that mates to the bulkhead Subaru harness for running the rest of the car. If you make that change yourself it is not expensive, but costs a lot for outside labor.
Still, it can be and often is done by the enthusastic person wanting a Subaru. I have done it both ways, first with the Suby computer and an Apexi thingy, now an Autronic M2. The Autronic is much superior but cost $1500 plus the wiring expense and tuning. Expect to spend $3000 if you pay to have it done for most any standalone. The cost of boy toys I guess.
If you are going to make the sacrifice to get your car going, on balance a standalone is the best route. I have heard that TEC2 is not a top level computer, but it does cost less and many people use it. Like the man sez, you get what you pay for. Success.
Mike McBride
91 Legacy 4EAT into 93 Legacy SSLegacyGT Transmission (AT/MT) & Driveline 4 11-10-2009 02:19 PM
ej20g into a 93 usdm impreza WantAnewCar88 Pre-2002 Factory Turbo Powertrain 3 07-14-2009 09:03 AM
Ej20g into my 93, but comes with Auto wire harness? my3awds Subaru Conversions 2 01-18-2006 05:31 PM
2.5rs (gc8) drivetrain into 93 impreza l fwd duratec Subaru Conversions 7 03-03-2005 11:33 PM
Ej20g into 93-97 early gc8 swap muhon Subaru Conversions 5 12-02-2004 11:25 PM
