Old 04-22-2004, 12:15 PM   #26
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Remember you still need a harness that mates to the bulkhead Subaru harness for running the rest of the car.
or use the 1.8 harness like i did
i took harness off 1.8 had to remove manafold
took the harness/manafold off the ej20g
changed around 2 pins in the tps connector
hooked up the water temp sensor
moved over the 1.8 crank sensor
connect oil pressure
connect power steering lever sensor(i used the 1.8 pump and bracket)
used the coil +12v as my "on" for the tec power (may change this tommarow tho..)
chucked the 1.8 knock sensor in the bucket o parts
wrapped the injector, cam sensor, knock leads together and out of the way
and yeah the tec 2 is not top level the tec 3 is tho
Old 04-22-2004, 12:32 PM   #27
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Correct
You are right Jaxx, thats what I said, one needs to connect with the bulkhead harness. Using the stock connectors is the only way unless everything is replaced with weatherpaks or duetsch connectors. What is your estimate for a paid professional to figure out and do what you outlined above? We agree I think.
Yes tec3 is better so I hear. Appropriately priced as well.
MM
MZM is offline   Reply With Quote
Old 04-22-2004, 01:25 PM   #28
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
professional .. the first time .. probblay 3-4 hrs min if he is familiar with subarus
Old 04-22-2004, 01:39 PM   #29
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Jaxx,
Sorry I never shot you that chart. I just assumed that you had a copy. as for the TD05's, Deadbolt just got a shipment that is clocked with the correct inlet for the older engines. And they are brand new, but they are also $800!
Skyliner,
That is something you will be limited by with an older engine like that, the turbo choices. It all has to do with the inlet. But you sound like you are ready to go for a build, so let me make a suggestion. Get modern EJ20 heads along with the intake manifold and fuel rails. Basically it will entail buying a second engine and taking the top end off of it. Used complete longblock can be found in the classifieds for $500-700 fairly often. Sell off the block for $250-300 and use the rest for your build. Not only will this get you away from the old HLA heads, but it will reroute your intake plumbing and make it so you can get any modern IHI or Mitsu turbo that you want down the road. Also, you can likely sells your HLA EJ20G heads to one of the Legacy Central guys looking to do a DOHC conversion on their EJ22. I would have gone this route if I had more money to work with up front. Unfortunately, I've got too many projects and that extra couple grand is sunk in some Cobb heads.
But with a closed deck block and modern heads and a big turbo you can very quickly have your car at 300hp for not a lot of money, on the relative scale of things...
Old 04-22-2004, 05:34 PM   #30
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i am betting it cam from the same place i got mine .. simmilar to what i posted above..
tdo5: yeah that price sucks, more than a vf-34, hell no espically when they go for ~$40 on the yahoo.jp auctions
Old 04-22-2004, 05:38 PM   #31
Matt Monson
Member#: 832
99 2.5RS, '85 911
Actually it is off of a Japanese site that I came across a few months ago when I started doing Legacy research...
Old 04-24-2004, 01:16 AM   #32
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
with a NZ address?
got the chimeny today 1 bolt lines up .. after considreable cutting ...
oh wells
i finnnaly found my phantom shut off proublem, a cracked battery terminal .. the tec won't fire the coil at all below 10v
of course in the process i broke the intercooler charge pipe the air to air version is plastic
Old 04-24-2004, 07:12 AM   #33
skyliner33v
Member#: 2675
MY02 Wagon 350whp
Hey,
I'm not sure if you've seen the private classifieds lately, but there is someone selling an ECU and harness for an EJ20G and I was wondering if I could use this for my swap.
Here is the link.
http://forums.nasioc.com/forums/show...hreadid=546410
And I PM'd you Matt.
thanks
jason p.
skyliner33v is offline   Reply With Quote
Old 04-24-2004, 06:21 PM   #34
Matt Monson
Member#: 832
99 2.5RS, '85 911
replied...
Jaxx,
I am sorry to hear that isn't a direct fit. But you made it work, eh?
Old 04-24-2004, 07:35 PM   #35
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Old 04-24-2004, 09:17 PM   #36
Matt Monson
Member#: 832
99 2.5RS, '85 911
jason p.
you have a new PM...
Old 04-28-2004, 04:01 AM   #37
skyliner33v
Member#: 2675
MY02 Wagon 350whp
PM'd you back.
91 Legacy 4EAT into 93 Legacy SSLegacyGT Transmission (AT/MT) & Driveline 4 11-10-2009 02:19 PM
ej20g into a 93 usdm impreza WantAnewCar88 Pre-2002 Factory Turbo Powertrain 3 07-14-2009 09:03 AM
Ej20g into my 93, but comes with Auto wire harness? my3awds Subaru Conversions 2 01-18-2006 05:31 PM
2.5rs (gc8) drivetrain into 93 impreza l fwd duratec Subaru Conversions 7 03-03-2005 11:33 PM
Ej20g into 93-97 early gc8 swap muhon Subaru Conversions 5 12-02-2004 11:25 PM
