#1 |
Member#: 1229
Vehicle:MY00 Impreza GT Forged EJ205, 276 whp |
Hi guys/gals!
Does anyone know the lowest posssible offset that can be used on the Impreza without causing rubbing on the rear wheels...? I'm Swedish...and got a -00 GT...even though it's a turbo I believe it shares the same offset as your RS's...55...right? I'm curious...since I've found a nice 18" wheel, but need to know which amount of offset I'll need. ![]() Thnx - and have an Impreza weekend! //SAM
#2 |
Member#: 1229
...noone knows....(?)
#3 |
Dynamic Uno
Member#: 1
BAIC
Vehicle:2011 Impreza WRX STi Black |
On a 17x7 rim +48 is maximum. Some 17x7.5 rims come with +45 and they are ok, as long as the car is not lowered. So for your 18" rim, you need to keep the same overall diameter as the 17x7 with 215/45/17 tire and +48 will be fine, I think.
#4 |
Member#: 1229
Thanks!
![]() I'm looking at a Team Dynamics wheel, the motorsport, they can be had with 50 mm offset...and it's available in 18x7... The more sane choice would be an OZ Superleggera, it's in 17x7 and offset in the 48 range. :-) CYA //SAM [This message has been edited by SecretAgentMan (edited May 14, 2000).] |
#5 |
Member#: 252
Vehicle:2001 Arctic White Camaro SS #1800 |
the 50mm offset should be fine, but you'll be using rubber bands for tires on an 18" wheel.
| Thread Tools | |
| Display Modes | |
| FS : (CNJ) Konig Afternurners 18x7.5 | 04.STI | Tri-State Area Private Classifieds | 8 | 06-04-2010 06:54 PM |
| 48mm offset vs 51-53mm offset on wagon | WRXinEffect | Brakes, Steering & Suspension | 4 | 02-09-2003 03:31 PM |
| 48mm offset vs. 53mm offset | Rexkid | Brakes, Steering & Suspension | 1 | 12-15-2002 05:16 PM |
| 48 offset compared to 53 offset | SK00Impreza | Brakes, Steering & Suspension | 18 | 07-31-2001 10:02 PM |
