Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-12-2000, 01:12 PM   #1
FatChanceTi
Member#: 274
Post
if you have to dis, or re-assemble either of the struts, you will need a longish 17mm socket head, and a metric allen wrench (I forget the size, maybe 6mm or 8mm) I would also recommend having a small pipe wrench to turn the socket with.
the allen wrench is to keep the whole strut from twisting, the 17mm socket will be unbolting the pillow mounts/top hat assembly. You need to stick the wrench through the hole in the socket....it's a pain...
probably hard to picture this unless you've done it, but hopefully this will help...
ryan
FatChanceTi is offline
Old 05-12-2000, 01:14 PM   #2
BryanH
Member#: 993
Post
It really is simple. Just be sure to have plenty of brake fluid on hand. And dont forget your spring compressor. I would also recommend an impact wrench and breaker bar.
BryanH is offline
Old 05-12-2000, 02:11 PM   #3
chrisj
Member#: 582
1999 Impreza RS
Post
It looks like i won't have to mess with the brake lines. do they need to be disconnected?
chrisj is offline
Old 05-12-2000, 02:36 PM   #4
SubyPrez20
Member#: 957
2002 WRX Wagon
[email protected] [email protected]
Post
Ok, I'm jealous. This sucks.
Wishing you luck, and cant wait to get a ride in it next weekend! I know some GREAT twisties for ya. And dont forget, if you want, you can come with me for a nice little twistie ride. With my Pirelli's, I can do the twisties course in over 30sec's faster, and take 4 of the turns over 18 mph faster.
Suby
[This message has been edited by SubyPrez20 (edited May 12, 2000).]
SubyPrez20 is offline
Old 05-12-2000, 02:48 PM   #5
bluesaint
Member#: 876
Post
U don't need to bleed the brakes .. just cut through the clip and make sure u dont' cut the brake cable and take it out of the U thing. its simple
bluesaint is offline
Old 05-12-2000, 06:56 PM   #6
N/A
Member#: 133
TBA TBA
TBA
Post
Yep just use a dremmel Or what ever it is called to cut one side of the clip then use pliers to bend the clip out of the way. Pull the brake line out and that is it. Cut it the same way on the new struts and slide it in then bend the clip back and slide the extra cover piece over the clip. If you are intending to do it in the future you may want to install new stainless steel brake lines while you are at it. Then you can also swap in new fluid. Beats the hell out of doing it all over again later on down the road.
N/A is offline
Old 05-13-2000, 12:52 AM   #7
chrisj
Member#: 582
1999 Impreza RS
Question Suspension Install
Is there anything that I should know? It looks similar to a vw install. Two bolts at the bottom and the top bolt. Am I missing anything?
chrisj is offline
Old 05-13-2000, 06:22 PM   #8
cincyRS
Member#: 1010
Post
The installation is easy, you dont need the allen wrench or the spring compressor, I did this with my wife a couple of months ago. The stock springs are under maybe and maybe is a bog word 1 or 2 lbs of pressure in the mounts. Easy job to do, any questions email me
cincyRS is offline
Old 05-13-2000, 06:29 PM   #9
CM
Member#: 367
98 Impreza RS
(sold)
Unhappy
How do you get the top piece off the front struts without the allen wrench? Mine are stuck!!!
CM is offline
AZP Installs -Your Tri-state Brake and Suspension Installers- AZP Installs Suspension/Brakes/Handling 10 09-09-2008 07:35 PM
Suspension install/Baby Sacramento-Area Install fest Kostamojen Bay Area Impreza Club Forum -- BAIC 24 03-29-2002 06:40 PM
Uh, myk ain't the only one that needs suspension install help... gtguy Mid West Subaru Owners Club Forum -- MWSOC 14 01-10-2001 10:15 AM
Question about impending suspension install... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 14 01-10-2001 09:33 AM
wheel alignment after suspension suspension install bluesube Brakes, Steering & Suspension 0 11-02-2000 03:23 PM
