Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-18-2004, 01:58 AM   #1
dragone
Member#: 58731
2004 FXT
java
Default What kind of mpg is your 5spd turbo getting?
It confuses me that the Baja weighs 400lbs more then the Forester, yet is rated to get better hwy mpg.
I'm thinking the final drive ratio of the Baja is taller then the Forester. Does anyone know what that is? Is there a chart of the max speeds for each gear for the Baja?
If nothing else, could someone let me know what rpm they're at when driving 70mph?
Thanks!
dragone is offline   Reply With Quote
Old 04-18-2004, 12:11 PM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I dont know about the turbos but alot depends on your driving style.
Our NA Baja gets up to 400 miles out of a tank on the highway with semi-conservative driving.
250 to 300 miles out of tank in the city.
if you stay out of theb oost you should be able to get close to those figures....not quite but close.
And yes, I beleive the Bajas are geared a lil taller than the foresters. Aerodynamics may also play a role. I think the Baja is more areodynamic.
Samirr76 is offline   Reply With Quote
Old 04-19-2004, 12:43 AM   #3
hatake
Member#: 34811
04 Baja T
Currently I have 6000 miles even (2 oil changes, still 5-30 Castrol), and averaging around 23+ mpg on 75% highway, conservative driving style. Mileage is improving:
hatake is offline   Reply With Quote
Old 04-19-2004, 12:53 AM   #4
dragone
Member#: 58731
2004 FXT
java
Good job with the chart.
can you give me some speed, gear and rpm measurement to gauge the difference in final drive ratio's?
preferably something like 70mph in 5th = n RPM.
Old 04-19-2004, 04:00 PM   #5
ez bturbo
Member#: 56048
2004 baja turbo 5spd
black/dark gray
75% highway driving here, and I was getting 20-21mpg on a 5 speed turbo. Now, after about 3500 miles it seems to be over 22. I was hoping for a bit higher, hopefully it keeps going up.
ez bturbo is offline   Reply With Quote
Old 04-19-2004, 10:52 PM   #6
dtesta
Member#: 52587
2004 Bajo Turbo
Just over 23 with about 75% highway driving. Up about 1.5MPG since new (3800 miles now)
dtesta is offline   Reply With Quote
Old 04-20-2004, 09:46 AM   #7
Samirr76
Member#: 4835
2003 Baja 5MT
well dont feel bad u guys are getting about the same mpg as my wrx.
not bad for a turbocharged truck!!
Old 04-21-2004, 08:15 AM   #8
hatake
Member#: 34811
04 Baja T
I forgot about the rpm at 70 mph. Sorry, someone else have to report that - I'm in japan now and can't drive Baja Turbo (sucks).
Old 04-22-2004, 10:32 PM   #9
JerZBajaT
Member#: 54980
2004 Baja Turbo
Talking MPG & RPM
With 85% HWY driving, and about 9200 miles on my T, I'm averaging around 23.2 MPG. When I'm driving conservatively I get almost 24 / but usually it's more like 22.8 ;-}
Cruising at 70 MPH - I'm turning about 3100 RPM in 5th.
JerZBajaT is offline   Reply With Quote
Old 04-22-2004, 10:46 PM   #10
dragone
Member#: 58731
2004 FXT
java
I was expecting a lower RPM for 5th. In my FXT, I'm right at 3k RPM also when doing 70. Maybe a little higher, so that makes me believe that we have the same rear ratio's.
What kind of mpg do you get? bomber991 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 11-08-2007 05:31 PM
What kind of MPG are JDM swaps getting? powerlabs Subaru Conversions 41 06-29-2007 02:14 PM
what kind of shape is your Drivers License in? alacrity024 Off-Topic 26 12-12-2006 06:37 PM
