Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-31-2000, 05:07 PM   #1
Joe Hogan
Member#: 699
2002 golf TDI
Post Synthetic Power Steering fluid FYI
For those of you changing your power steering fluid to a synthetic fluid here is Redline's recommendation
"My Subaru 1999 2.5 RS recommends Dextron ATF for the Powersteering unit?? ....
What do you recommend for the Power Steering unit? ..."
Redline's answer: "In your power steering, I would recommend the Red Line D4ATF as a Dexron III is called for."
FYI JOe Hogan
Joe Hogan is offline
Old 07-31-2000, 06:17 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
That reminds me, I need to replace my fluid with synthetic before I run at Lime Rock in a few weeks. I get a *little* bit of overflow from the power steering reservoir when I run it on the track, so I want to see if synthetic's better heat capacity will fix the problem, or if I need a power steering cooler.
Pat Olsen
'99 Legacy 2.5GT 5speed sedan
Patrick Olsen is offline
Synthetic power steering fluid? Rev1 Service & Maintenance 17 03-29-2008 10:20 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Power Steering Fluid / Steering Shimmy + Noise Altaic Brakes, Steering & Suspension 4 04-24-2006 12:59 AM
Power steering fluid or ATF? SubieFL Normally Aspirated Powertrain 4 03-30-2001 06:25 AM
