Old 04-18-2004, 03:53 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default Turbo porting problems
I finally got a change to take my turbo out and port the wastegate, but it didn't quite work. I took out a good amount of material, and it seems like creep is slower, but I still get up over 10psi when the wastegate is set to 5. At partial throttle or in lower gears, I get 5-6 psi and it stops. But sometimes in higher gears though it justs keeps going and I have to let off once it hits 10psi. Is it possible that the wastegate just isn't going to let me run this low of a boost? The turbo is a VF30.
I don't really want to take the turbo off again, so I'm going to start researching pop off valves to limit my boost. Any ideas where to start looking?
lotusTT is offline   Reply With Quote
Old 04-18-2004, 11:32 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I thought they had springs set for 8 psi...
Old 04-18-2004, 11:46 PM   #3
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Greddy makes a Pressure relief valve, forget how low it goes though.
www.greddy.com
Bobalouy is offline   Reply With Quote
Old 04-19-2004, 12:27 AM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
that greddy valve looks perfect, it looks like it goes 1-25psi. Thanks!
Old 04-19-2004, 01:49 AM   #5
Avenger
Member#: 1234
Make sure your vacuum line is hooked up correct. I hooked mine up wrong before and it went up to 10 psi on my 7psi spring. I can't remember of the top of my head but I think only the nipple on the side is connected and the top nipple is not connect. Oh btw my wastegate is the standard HKS one.. so not sure if it applies to you.
Avenger is offline   Reply With Quote
ODB2 Port Problem oosoceroo Electrical & Lighting 0 06-29-2006 10:26 AM
Diagnostic port problem evil02wrx Newbies & FAQs 10 04-25-2006 03:24 AM
for txs - port problem - fixed! Smoke Show Engine Management & Tuning 0 09-23-2005 03:44 PM
help acess port problem bobert517 Engine Management & Tuning 6 03-20-2005 12:05 AM
VB serial port problems - help il96 Off-Topic 4 10-01-2004 04:40 PM
