Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-12-2000, 09:25 AM   #1
Tim Prudence
Member#: 216
Post ITC switch settings (been searching for 15 minutes)
Sorry I know this has been posted before but I can't find it. Does anyone know the proper switch settings on the ITC for our cars (I know car select should be 5). Specifically I want to know which is the switch that allows toggling between the +/- 5 degree safety mode and +/- 15 degree full adjust.
Thank you!
Tim Prudence is offline
Old 05-12-2000, 09:55 AM   #2
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
the switch to change from +/-5 to +/-15 is the first one. Don't remember if up is 5 and down is 15, though. BTW, it's in the ITC manual
Strepto is offline
Old 05-12-2000, 10:09 AM   #3
Tim Prudence
Member#: 216
Post
Thank you!
I got my ITC used and I didn't get a manual with it. All the other switches are supposed to be up, right?
Old 05-12-2000, 10:14 AM   #4
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
Doh, I'm at work right now so I can't go look (even though I'm not sure where the manual is anyhow). I'm sure a few others here can help out. I know for sure it's the first switch, but I don't remember what position is what setting. As far as I remember all other switches should be up.
Strepto is offline
Old 05-12-2000, 11:19 AM   #5
Tim Prudence
Member#: 216
Post
Never mind, I finally found it:
The 1st dip switch is to limit timing adjustments.. should you wish to go more than +/- 5 degrees, push that switch down.
Been Searching for a while, but no luck... Hyelude Newbies & FAQs 0 06-23-2009 02:18 AM
Been searching for hours.. nismo4life General Community 2 01-14-2008 10:58 AM
been searching for install instructions! rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-27-2006 09:35 AM
Been searching for an hour! buyos1717 General Community 18 04-21-2005 01:37 PM
MUSIC TRADE ON GOOGLE! NOW! SIGNUP FOR THE TRADE (will take place in 15 minutes) Nightwing Off-Topic 6 11-10-2004 10:54 PM
