Old 04-18-2004, 05:27 PM   #1
tobRS
Member#: 24440
05 lgt
Default exhaust leak?
I just put on the TWE headers and got new gaskets for them, but now im gettin smoke from where they connect to the manifold. Would this be an exhaust leak? If so, how do i got about fixin it?
tobRS is offline   Reply With Quote
Old 04-18-2004, 05:55 PM   #2
tobRS
Member#: 24440
05 lgt
hah, I think it was just the penetrent burning off because the smokes seems to lessen as it idles.
I am getting some water out my exhaust tho, think that will go away?
anyway, time for ecu reset and a drive.
Old 04-19-2004, 01:47 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
new headers/piping will smoke at first,
takes a bit of driving for that to burn off...
there's typically some condensation in most exhausts..
get out there and get on it and it'll burn off
Jamie
www.subiegal.com
Old 04-19-2004, 02:30 PM   #4
tobRS
Member#: 24440
05 lgt
the smoke is gone, but I think there is a leak though. When I let off the gas there is kind of a hissing noise followed by a pop ever once in a while. I'm guessing its from the header to the cat. I'm just going to try to tighten the bolts some more, or maybe get some sealant and redo it. Anyone know exactly what kind works best?
Thanks
Old 04-19-2004, 04:48 PM   #5
Section 8
Member#: 821
Let the car idle (secure it from rolling ) then skid yourself under it by your header. You will know if you have a leak. If not, it might only leak when you are on the throttle.
An exhaust leak will not manifest itself only when you let off of the accelerator (the exhaust traveling out the pipe has momentum, and causes a vacuum at the valves which now have wery little exhaust coming out ot them, since the throttle body is closed). Exhaust leaks also rarely "hiss" (unless it is a leak before a turbo), exhaust travels in pulses, and almost all exhaust leaks will be a pst pst pst pst, or a tapping sound.
THe pop is going to be a normal occurance.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Chirping noise. Boost leak? Exhaust leak? DriftIt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-11-2014 06:45 PM
Exhaust Leak & Vaccum leak similar drizzleboy Service & Maintenance 0 03-05-2010 06:46 PM
Traded exhaust leak for intake leak Saopaulo54 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-21-2010 10:28 PM
boost leak or exhaust leak? sc0013z Texas Impreza Club Forum -- TXIC 42 02-17-2008 09:08 PM
Exhaust Leak sound that isn't an exhaust leak? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-08-2004 10:28 PM
