Old 04-18-2004, 07:53 PM   #1
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
Default EJ18-> EJ25 Dyno results
So ive been running around with a SOHC EJ25 running off my EJ18 ECU in my 1995 L AWD 5 speed. I only have a cone filter and exhaust done (borla headers, no cats, dynomax glasspack, flowmaster 40 series all 2.25" piping) I went with my Audi buddies this saturday and my car eneded up on the dyno.
116.1 HP @ 5,500 RPM
122.9 Torque @ 4,500 RPM
THese were done on a mustang dynamometer on a beatiful 70 degree day. THe results were better than I was expecting, considering my car had 110HP at the flywheel originally.
Just thought Ide post this in case anyone was wondering.
Hawk296 is offline   Reply With Quote
Old 04-19-2004, 02:05 AM   #2
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
That seems low for the mods, but that redline and EJ18 ECU probably didnt help...
Old 04-19-2004, 07:39 AM   #3
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
It was actually more than i was expecting. You should have seen the black smoke it was spewing out too. I never did get around to leaning out the mixture. Another interesting thing which I have never experianced before was alittle detonation top of 4th. I guess with my car being so light ive never had that much load on it untill it was tied down. 2nd run went fine though. It was interestnig to see max power was made so high at 5,500 then leveled off until redline.
Just for comparison sakes, an A4 1.8t quattro with a chip, exhaust and a K04 turbo upgrade ran 129HP to the wheels right before me.
Old 04-19-2004, 08:53 AM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: EJ18-> EJ25 Dyno results
Looks like a pretty good gain! What air/fuel ratio were u running with the black smoke and all?
Kevin Thomas is offline   Reply With Quote
Old 04-19-2004, 06:08 PM   #5
tootifrooti
Member#: 59953
1996 Audi A4
Red
I think the dyno was way off there, the a4 1.8t has over 160hp stock, and would have close to 180-185 with the mods you listed. I would run it again if i were you
tootifrooti is offline   Reply With Quote
Old 04-19-2004, 06:18 PM   #6
quest
Member#: 42402
- Finder of Porn
-Bringer of tears...
180 at the crank should be around 129 at the wheels...doesn't sound off to me.
quest is offline   Reply With Quote
Old 04-19-2004, 06:23 PM   #7
HondaH8er
Member#: 3097
2000 2.5RS Coupe
Silverthorn Metallic
Yeah, this is wheel, not crank HP he got from the dyno. Sounds about right to me. But I'm guessing the EJ25 ECU will net you even more power.
HondaH8er is offline   Reply With Quote
Old 04-19-2004, 08:31 PM   #8
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
No doubt the EJ25 ECU would give me more power but i was pleased with what i got with the 1.8 ECU. It was alittle better than I expected. TO be fair i think the A4 was messed up. A different, totally stock 2001 5 speed quattro 1.8t A4 with engine package (170HP) ran a 127 to the wheels on the same dyno also. For being the easiest swap to do, I think it was worth it.
Old 04-19-2004, 09:39 PM   #9
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
An Impreza L is a lighter car than an A4 too, so your car should hold it's own against the 1.8T, despite being a few hp behind.
wagman01 is offline   Reply With Quote
Old 09-18-2004, 09:23 PM   #10
Kevin Thomas
Member#: 110
1989 1989 XT6
Hello Hawk,
Any updated dyno information on your ride? Did you ever get an EJ25 ECU? Just curious!
Old 09-21-2004, 09:30 PM   #11
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
Heeeyyyyyy!. Thats wack fool..... I tested at
112.3HP @ 5500
121.6 torque @ 4500
AWD Auto EJ25 DOHC
Borla Header
Stromung High Flow
Im guessing its because im an automatic?
Honkey3k is offline   Reply With Quote
EJ18 -> EJ25 -> eJ22 help tooocool49723 Subaru Conversions 4 10-02-2007 12:07 AM
EJ18 -> EJ25 ECU questions therambler07 Normally Aspirated Powertrain 12 01-08-2007 09:06 AM
EJ18 -> EJ25 swap, leftover parts. 83Rabbit Mid Atlantic Impreza Club -- MAIC 4 10-03-2005 03:21 PM
ej18 ej25 SWAP Dyno Results, HEADS UP! maxim Normally Aspirated Powertrain 6 03-18-2005 08:34 PM
ej18 ej25 SWAP Dyno Results, HEADS UP! maxim Subaru Conversions 8 03-18-2005 08:22 PM
Message Board Statistics All times are GMT -4. The time now is 11:12 PM.
