Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 04-18-2004, 08:40 PM   #1
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
Default options for fuel pumps for RS
Still battling with my lean condition on my 99rst. It does it in first gear and from take off (idle to about 2000rpm). I am probably going to take my car to Dan at godspeed for him to look at it.
Is there any options other than the walbro fuel pumps out there?
Can anyone comfirm if the walbro gss342lph will fit my car?
I have done the svx fuel pressure mod because of the walbro fuel pump in my car currently, because of the high output.
Does anyone know if when I replace the fuel pump if this will drop my fuel pressure below the factory specs (because of the fpr mod)?
Thanks a bunch
chris
25rstautoxr is offline   Reply With Quote
Old 04-18-2004, 09:37 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
the walbro for the wrx fits
supra
wrx...not too strong
Old 04-18-2004, 10:38 PM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
It sounds like you are having more of regulator issue than a pump issue. If your pump weren't up to the task you would see your car lean out towards redline, you are seeing the opposite.
no-coast-punk is offline   Reply With Quote
Old 04-18-2004, 11:29 PM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Do you have a fuel pressure gauge installed?
Just for reference, I have an MKIV Supra TT pump, and the SVX FPR: Idle pressure is at 30psi, and at boost its steady at 43psi.
Wedge is offline   Reply With Quote
Old 04-19-2004, 10:43 PM   #5
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
yes I do have a fuel pressure gauge installed under the hood. at idle I am around 30psi and at atmosphere I am at 42ish (pulling the vaccum line off the fuel presure regulator). At boost it climbs around the fifties.
The reason I am thinking of replacing the pump is because I was sitting in my garage with the car running (garage door was open!) and the instead of a steady hum from the fuel pump it was buzzing from high to low and back to high and the 02 gauge was wondering from lean to stoch. (hows that for a run on sentence).
So yes the gss342 walbro will fit??
thanks
chris
fuel pump for my RS White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-25-2003 03:09 PM
MA: ATTN: 99 RS Turbo Projects - I have injectors and a fuel pump for you! K2Skier Private 'For Sale' Classifieds 0 10-08-2003 05:43 PM
ATTN: 99 RS Turbo Projects - I have injectors and a fuel pump for you! K2Skier New England Impreza Club Forum -- NESIC 0 10-07-2003 10:16 PM
ATTN: 99 RS Turbo Projects - I have injectors and a fuel pump for you! K2Skier Private 'For Sale' Classifieds 0 10-07-2003 10:15 PM
Uprated fuel pump for turbo RS? blitzpb Normally Aspirated Powertrain 10 03-02-2001 11:58 AM
