Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-11-2000, 01:18 PM   #1
Dan00RS
Member#: 1367
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
Actually you want to do this when the engine is warm (doesn't have to be hot!) Metal expands when it is warm. The threads on the valve cover will expand more than the metal of the plug threads. Aluminum expands at a lower temp. This will make it easier to remove the spark plugs and you won't have to worry about stripping threads. Be sure to put anti-seize on the threads of the new plugs so it will be just as easy to remove them next time.
Dan00RS is offline
Old 05-11-2000, 01:26 PM   #2
Bassem
Member#: 305
Post
How much anti sieze should one put? Enough to "wet" all the threads, or should there be a few blobs as well?
Thanks,
Bassem
Bassem is offline
Old 05-11-2000, 02:02 PM   #3
Rajah
Member#: 362
2006 WRX STi
WRB / Gold
Wink
No blobs! Just wet the threads enough around the bottom so that it'll spread as you screw them in. Dielectric grease is also a good idea wherever the plug wires make contact (coil & plugs).
Rajah is offline
Old 05-11-2000, 02:18 PM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Don't do it when the engine is warm! When you torque the new plugs in to the proper setting, the engine block will shrink as it cools, thus increasing torque by an undeterminable amount. The torque specs are given for a cold engine.
The plugs aren't hard to unscrew when it's cold anyway.
~G
RidinLow is offline
Old 05-12-2000, 12:34 AM   #5
Bassem
Member#: 305
Post At what engine temp to change spark plugs??
Just curious as to what temp should the engine be at when you swap plugs. I recall it should be cold so you don't strip the aluminum threads. This is correct, no?
Thanks,
Bassem
Bassem is offline
Old 05-12-2000, 12:52 AM   #6
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
I would have thought it was sensible when cold so as to not burn your hands
paul
PaulN is offline
What Is the BEST WAY to Change Spark Plugs?? george3 Service & Maintenance 17 10-31-2009 10:11 PM
Trying to change spark plugs - can't get socket on plug winston856 Service & Maintenance 5 03-18-2008 05:42 PM
When to change spark plugs & what brand to use? Bradus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-01-2004 01:53 PM
Help, how to change spark plugs Hanzo Service & Maintenance 14 01-21-2002 10:57 AM
How to Change spark plugs on a Phase I DOHC? yebokmj Normally Aspirated Powertrain 5 01-21-2001 04:44 PM
