Old 04-19-2004, 09:52 AM   #1
wrX-RTD
Member#: 34969
03 WRX mbp
vf34 ap 2.5
Default turbo upgrade information?
well the mod bug is biting me again. the performance im getting out of the stage 2 just doesnt seem to be enough at times.
i almost did a deal a while back for a vf30 and sti injectors but decided not to after a lot of thought. i had been told that first gear would be essentially non-existant and that i couldnt shift aggressively whatsoever. my transmission/clutch would supposedly not last long under the new setup either.
who all is running a larger turbo on the stock drivetrain, etc? any problems?
basically, do what you can to convince me whether or not to save up for a new turbo setup.
thanks again,
-dustin
wrX-RTD is offline   Reply With Quote
Old 04-19-2004, 10:14 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Try posting in Factory Turbo 2.0L
scoobyimprza is offline   Reply With Quote
STi turbo upgrade vs. wrx 06+ turbo upgrade hockeygm General Community 5 03-27-2007 08:55 PM
Upgraded Turbo Owners: Information checklist samwY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-23-2004 05:52 PM
ECU upgrade or Turbo upgrade??? 1Slow///M3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-07-2003 12:17 AM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 01:31 PM
Turbo Timer Information Needed Syntax Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-28-2002 04:47 AM
