Old 04-19-2004, 07:53 PM   #1
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Default Psi!!!???
What PSI are people running on stock blocks? just wondering, guess i have to run 7-8 now and i was hoppin for 5.
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-19-2004, 09:49 PM   #2
Aphex
Member#: 146
'16 WRX Limited
tip 1. no !!!???? in the subject line.
on to the topic......... Is it a stock WRX turbo?
if so then it should be just fine at 7-8 psi, as it doesn't push as much cfm as other turbo's at the same pressure levels.
gurus correct me if I'm wrong.
Aphex is offline   Reply With Quote
Old 04-19-2004, 10:15 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Tip #1 was well put... I've edited your thread title, please keep in mind there are rules here
Aphex is right. 7-8 is max, and something more likely then not will break. Main reasons:
1. Too much boost
2. Not enough octane
kastle is offline   Reply With Quote
Old 04-19-2004, 10:15 PM   #4
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
I ran 10.5... then my motor blew.. ha ha .. stoopid boost. Now I am fully built and ready to blow this one up too.
Pi7467mp is offline   Reply With Quote
Old 04-20-2004, 08:38 AM   #5
squirrelmasta
Member#: 33445
Cherry Red
First off, WOW! didn't know the ? was so illegal in a topic line, and WOW you guys really know the rules here.
Kastle i don't get your post. you aggreed with Aphex and then said something different. or am i just reading it wrong?
-Eli
Old 04-20-2004, 12:18 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I was agreeing with him and expanding on why only 7 - 8 psi is the max on a stock block.
Old 04-20-2004, 01:02 PM   #7
squirrelmasta
Member#: 33445
Cherry Red
rock on. Thank you.
-Eli
Old 04-20-2004, 05:35 PM   #8
kaos200
Member#: 2692
I ran 12psi on my stock 99' block (tuned mind you), lasted for a while, the rods finally gave out on a rev in NEUTRAL of all times
edit, I ran that much because I had my spare motor in the garage, haha
kaos200 is offline   Reply With Quote
Turboxs stage 2 power, 14 psi vs. 17 psi, 91 octane 93 octane Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-06-2002 11:26 AM
How much PSI is too much PSI? virus67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-15-2001 06:48 PM
How many PSI is too many PSI? virus67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-03-2001 10:39 PM
Bosche BOV leaks over 7 psi, need recs for BOV for 0-12 psi ImprezaRS dot com Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-10-2001 11:25 PM
