Old 04-19-2004, 08:44 PM   #1
kmschwem
Member#: 44555
Default Simple oil change interval dbl check
Just wanted to check what I'm reading in my MY04 manual. Is the oil change interval above 7500 miles every 7500 miles? Seems pretty high since synthetic isn't specified.
Just double checking that I'm reading this maintenence book right.
Thanks
kmschwem is offline   Reply With Quote
Old 04-19-2004, 09:21 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes, and it really isn't high. 7,500 is fine for most cars.
Old 04-20-2004, 06:36 AM   #3
Hayes
Member#: 11808
Sense I do about 50% driving under 5 miles per trip I split the difference between 3750 and 7500 miles so I change oil& filter at 5,000 miles. Ed Hayes
Hayes is offline   Reply With Quote
Old 04-20-2004, 09:11 AM   #4
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Why do people have such a hard time deciphering the manual?
7500 miles is the extended drain interval for non-severe driving.
3750 is the drain interval for severe driving.
Determining which interval to use is up to you, depending on your driving habits. Lots of short trips? Redline it all the time? Then you should probably follow the severe driving schedule. But if all your trips are on the highway and you spend all your time at 2k rpms in 5th gear, then you'll probably be fine with the non-severe schedule.
heffergm is offline   Reply With Quote
Old 04-21-2004, 09:59 PM   #5
chaddeus
Member#: 56624
2004 Subaru WRX STi
Generally, on average, should they change 7500 miles or 3750? Because I drive normally, local and highway.. Once in a while, I drive to like 6k RPM
So what am I?
- Charles
chaddeus is offline   Reply With Quote
Old 04-22-2004, 12:01 AM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
So what am I?
- Charles
Abnormal since you don't redline it! Otherwise, I would say you are normal as far as the service manual is concerned.
Mobile 1 Oil Change Interval Sordid Philosopher Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-28-2002 09:56 AM
Best oil/change interval for Bay Area Climate Mean Rex Bay Area Impreza Club Forum -- BAIC 2 04-26-2002 05:08 PM
motul oil change intervals cantex Texas Impreza Club Forum -- TXIC 13 01-18-2002 03:38 PM
Synthetic oil changing interval poll bluesubie General Forum Archive 19 01-18-2001 08:29 AM
Oil Change Intervals Tim K. Technical Forum Archive 4 06-02-2000 08:37 AM
