Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 04-19-2004, 09:03 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Question EJ25 DOHC heads on SOHC EJ22
I sourced out a set of MY97 Legacy heads from a 2.5L DOHC. Both bank's cams are broken so I'll get some $ off the total price. a bearing for one cam at the end near the broken cam gear looks angled, and one exhaust stud missing.
I did do some searching and assume the heads are a direct swap. Will these DOHC affect my ECU in any way? I don't think so because it's not a AVCS head.
Where to find the valve covers for this....
How well does the dual port EJ22 head's in the early 90's Legacy's flow compared to the EJ25? The EJ25 might have a higher valve lift.
EDIT: I have a MY99 EJ22
FuJi K is offline   Reply With Quote
Old 04-20-2004, 01:19 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
TTT
Old 04-20-2004, 01:31 PM   #3
Section 8
Member#: 821
The cam timing sensor wheel might be different. THe cam sproket from different years and engines have a different number of "nubs" behind them to read and verify cam position. If you do not get a cam wheel with the same number of nub, the ECU will not like it.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 04-20-2004, 01:52 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I was thinking of getting adjustible cam gears in replacing the broken ones so I can advance the intake and exhaust cams.
EDIT: Darn they don't make adjustible cam gears for Subaru.
Could just getting the earlier heads from a MY92 Legacy 2.2L, which has dual ports be better?
Old 04-22-2004, 12:37 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
TTT
How much better does the early MY90's 2.2L dual ports flow than my stock MY99 2.2L?
Old 04-22-2004, 09:27 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally posted by FuJi K
TTT
150-180cfm or thereabouts. I don't know how this compares to the single ports. But I do have a set that I would be willing to part with. Send me a PM with an offer and we can talk about it if you are interested...
NA EJ25 DOHC heads on a EJ205 block unforgiven2144 Built Motor Discussion 8 08-01-2009 06:47 AM
98 dohc heads on sohc block EastsideLegacy Legacy Forum 31 02-27-2006 11:42 PM
EJ22 with EJ25 DOHC heads? ringe Normally Aspirated Powertrain 5 02-24-2006 11:11 AM
