Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-10-2000, 12:34 PM   #1
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Question Frnt. strut tower bar install questions??
anyone know if you are supposed to tighten the nuts to the bolts with a ceartain amount of force (Torque), if so does anyone know what that torque rating is on a MY00? also, how tight are you supposed to tighten the center bar (JC Sports Bar), how much pressure against the mounts? just till it is firm, then tighten the nuts on either side?? thanx for the help.
joostin420 is offline
Old 05-10-2000, 12:57 PM   #2
Opie
Floresbian
Member#: 470
2015 Forester 2.0XT
'14 XV Crosstrek, '99 SF
Post
The three strut bearing bolts should be tightened to 12-15 ft/lbs.
Opie is offline
Old 05-11-2000, 01:11 AM   #3
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Post
Bearing??? i don't know very much on this, i thought you just unbolted the 3 bolts on each side install the mounts and tighten nuts back on to a torque rating, then install the center bar? right? what do you mean by bearing?? thanx for the help.
Old 05-11-2000, 01:37 AM   #4
8Complex
Member#: 922
04 FXT
Red
Post
Strut-Bearing Bolts - the bolts that hold the strut on (that bear all the weight that the car puts on the strut). You're looking at the correct 3 bolts.
8Complex is offline
Old 05-11-2000, 01:59 AM   #5
Opie
Floresbian
Member#: 470
2015 Forester 2.0XT
Post
Sorry for the confusion! The strut bearing bolts are the three on each side that you mount the strut bar to!
Opie is offline
Question on Strut Tower Bar Installation Neaners Brakes, Steering & Suspension 4 09-11-2003 08:55 PM
Cucso front strut tower bar install question subiefan Brakes, Steering & Suspension 11 09-22-2002 01:26 PM
strut tower bar install question flegg Brakes, Steering & Suspension 2 06-15-2002 02:38 PM
Rear Strut Tower Bar Install questions joostin420 Technical Forum Archive 3 05-17-2000 10:50 AM
Frnt. Strut tower bar hitting hood scoop backing plate joostin420 Technical Forum Archive 11 05-13-2000 01:24 AM
