Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-09-2000, 07:17 AM   #1
Thug
Choke Artist
Member#: 603
Post 22B style hood vents?
So what's the real deal w/the hood vents? Some people say they draw in cold air. Some people say they draw out hot air. I have them, and Im just wondering if when I make my intake heat shield if I should put a top on it or if I should allow the air to flow in from the hood vent.
later,
Nate
Thug is offline
Old 05-09-2000, 07:58 AM   #2
Ian Cook
Member#: 1228
1993 Group N Impreza
White (Mostly) ;)
Post
Warm air rises they are supposed to allow warm air out of the engine compartment, but in reality when the cars are shipped they have blanking plates on, as do all of the Euro spec turbos. Although these are very easily removed they do allow water onto certain electrical components ???? Bit of a trade off!!!
Ian Cook is offline
Old 05-09-2000, 11:12 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
The way they are located in the hood on the body it creates a low-pressure area outside of them which sucks out hot air. You can take them off but you have to worry about water getting in there from washing or rain. I suggest going to your local hardware store and picking up 6 5mm wingnuts to hold on the vents. Makes installation and removal a snap.
8Complex is offline
Old 05-09-2000, 08:00 PM   #4
Thug
Choke Artist
Member#: 603
Post
I run w/the passenger side one opened up all the time and I have no problems. The engine bay will get wet no matter what. A little bit more water wont hurt anything. Also, people make alot bigger deal out of getting your filter wet than is really necessary. It takes quite a bit of water to hydro lock an engine. And a little rain is not gonnna do that. A huge puddle might, if you had your intake real low.
Thug is offline
Old 05-09-2000, 09:26 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I managed to plow through a puddle with my intake run into the right fender and sucked up some water several weeks ago... it soaked my filter and the car had trouble running but it dried out by the time I got out of work.
Just a little story I figured I'd share about the water coming into an intake situation.
8Complex is offline
Old 05-10-2000, 07:01 AM   #6
daytonians
Member#: 920
2000 2.5 RS Impreza
Sedona Red
Post
The vents are also supposed to suck air from under the hood to help eliminate lift at very high speeds. I have heard others say there is a noticible difference. Personally I have trouble believing they can suck enough air to be of much use for ground effects, because the openning in the front for the radiator is so large. It will let way to much air in. I am debating on whether to close off part of the opening.
daytonians is offline
Old 05-10-2000, 09:20 AM   #7
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
Someone posted in another thread that the points on the hood where the vents are located are low pressure areas. As air passes over those spots, air from under the hood is sucked out. It's a method to keep underhood temperatures down. If you think about it, if the open air filter sits right bellow the vent, you have some hot air being run over the filter and therefore being sucked into the intake.
Strepto is offline
SoCal: Seibon Carbon Fiber Hood Scoop (STI Style) and CF OEM Style Hood Vents Reeper187 1993 - 2001 Impreza Specific Parts 9 03-25-2009 11:13 PM
silver 22B style hood vents Stranger 1993 - 2001 Impreza Specific Parts 10 11-06-2008 10:59 AM
22B Style Hood Vents 2point5_RS 1993 - 2001 Impreza Specific Parts 3 12-24-2007 07:00 PM
22B Style Hood Vents on WRX sherifx Interior & Exterior Modification 6 11-15-2001 06:05 AM
WTB: 22B replica hood vents IcedOutRS Interior & Exterior Modification 2 03-21-2001 10:07 AM
