Old 04-20-2004, 01:30 AM   #1
mycarsux
Member#: 32049
2010 sti
Talking i want power
did a couple of searches and stuff. just wonderin wat kind of turbo kits people recommend for the gda RS. im planning to stick to stock internals and keeping the boost at 5psi or maybe lower, dont wanna blow the motor. are the turbo kits easy to install? i want to save money and do it myself, but i have no experience in turboing a car watsoever. i kno the FAT kits dont require the engine to be lifted. im just wondering if it is relatively easy to install.
mycarsux is offline   Reply With Quote
Old 04-20-2004, 01:34 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
USE THE SEARCH?!
Old 04-20-2004, 01:36 AM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
kastle is offline   Reply With Quote
Old 04-20-2004, 01:45 AM   #4
mycarsux
Member#: 32049
2010 sti
i tried..i guess im not looking hard enough but i cant find anything on the difficulty of installing a turbo kit.
Old 04-20-2004, 01:47 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Depends on the kit.
Old 04-20-2004, 11:10 AM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
and one's level of mechanical skill.
HOK is offline   Reply With Quote
Old 04-20-2004, 04:01 PM   #7
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Depending on the kit, you will likely need to replace the oil pan (which involves lifting the engine some), or possibly tap the oil pan or one of the valve covers (FAT kit) for an oil return line. You will of course need to do some wiring with your ECU to install your engine management, and possibly install some sensors for your engine management, and for your gauges. Much of the other parts involve bolting things on such as your turbo and exhaust components, but you will also need to splice and connect various vaccum, breather and coolant hoses. This is pretty much the base of what might go into an install.
j
ilmaestro is offline   Reply With Quote
WANTED POWER STEERING RESERVOIR FOR WRX/STI ... turbo model mysubarusti4life Private 'Wanted' Classifieds 0 08-17-2009 01:47 PM
2007 2.5i I Want Power! speed89lg Built Motor Discussion 17 09-19-2008 06:05 PM
New owner, want power! NicKR5005 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-15-2004 01:13 AM
