Old 04-20-2004, 03:27 AM   #1
crk4
Member#: 43617
1976 Ford Bronco
R.I.P. Mark Vos, 96 ob
Default inexpensive options for my96 2.2 injectors
I have used search and didn't find much. What options do I have as far as inexpensive injectors? I will be getting either a Walbro or WRX fuel pump, but for the injectors I've been thinking about 2.2T 390cc i believe or Nissan Silvia ones.
Someone give me the heads up?
crk4 is offline   Reply With Quote
Old 04-20-2004, 07:25 AM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Default Re: inexpensive options for my96 2.2 injectors
You didn't find much because those are pretty much your options. Also try searching for "sidefeed" or "side feed".
wac is offline   Reply With Quote
Old 04-20-2004, 10:45 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
The Silvia injectors are 370cc. Those are good injectors. I think the Legacy turbo injectors are right around 370cc also. STI makes some injectors that are in the mid 400s. How much power are you looking to make?
Brent
scoobyimprza is offline   Reply With Quote
Old 04-20-2004, 03:37 PM   #4
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Search wasn't doing to well for me either.Anyhow,I havn't ran these yet but it's an option.
http://forums.nasioc.com/forums/show...ghlight=todnar
Later,Tod
todnar is offline   Reply With Quote
Old 04-20-2004, 04:14 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I just put the red tops on my car. They are great for my application. The injectors are 280cc, which is ideal for my EJ18 engine plus the turbo. If you're looking, they're the injectors in all of the phase 1 EJ25 DOHC engines.
Brent
Old 04-20-2004, 05:04 PM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & 06 MCS
you can use the upgraded nissan injectors they are 50o and 700 cc injectors. the Yellow top JDM side feed injectors are 420, and they are very very hard to find.
subiekid is offline   Reply With Quote
Old 04-20-2004, 07:23 PM   #7
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
I am using the nismo 555cc injectors, they work great and are a straight drop in.
no-coast-punk is offline   Reply With Quote
Old 04-22-2004, 01:31 PM   #8
crk4
Member#: 43617
1976 Ford Bronco
Im lookin to make about 225-250 at the crank if possible.
My setup:
EJ22 N/a 142,600 miles
subachad pipes (didnt get downpipe yet)
greddy e-manage
wrx turbo, wrx intercooler
autometer boost and egt gauges
custom cold air snorcusectomy intake with k&n panel filter
borla 2.5" catback exhaust
and i need a few more parts...looking for cheap injectors
SUBIEKID: How's the WRX intercooler doing without the hood scoop?
Old 04-23-2004, 04:07 PM   #9
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
My setup:
greddy e-manage
Keep us posted on the Emanage, I'd like to see how that works out for you. I also sent you a PM regarding the Down Pipe.
Just got settled into the new shop.
Chad
www.uniquemotorsports.com
www.unique-motorsports.com
subachad is offline   Reply With Quote
Old 04-23-2004, 07:48 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I have a set, with fuel rails. But my understanding is they are 480cc...
Old 04-27-2004, 10:43 PM   #11
ttimpreza
Member#: 51587
Are you running a turbo? I'm looking for injectors for my 2.5 that i'm turboing. I found a set of yellow tops How much horsepower are they good to?
ttimpreza is offline   Reply With Quote
swap options for 97 legacy 2.5.. silverLegacy06 Subaru Conversions 10 06-13-2008 05:33 AM
New options for gear sets 2 (touge tuning) shamrock 05 Transmission (AT/MT) & Driveline 187 04-03-2008 06:57 PM
WTB: 5MT for a MY96 Legacy 2.2 Pakin NWIC Private Classifieds 1 07-10-2007 02:57 AM
Need ECU pinout sheet for MY96 2.2 NA (ecu model #2N) crk4 Engine Management & Tuning 3 06-26-2004 10:16 PM
options for an exhaust system on an MY96 1.8L westin_impreza Normally Aspirated Powertrain 8 01-27-2004 12:19 AM
Message Board Statistics All times are GMT -4. The time now is 07:52 AM.
