Old 04-20-2004, 10:58 AM   #1
youwrx
Member#: 59999
Unhappy Ecu Help
Hi all.
This is me first time
I have 2003 Subaru Impreza 2.0L non turbo I am going to install a turbo. I am installing a T3/TO4 turbo kit that comes with 2 extra injector. i will also install MSD dis2 for timeing.
the rev limiter in my car is 6.200 rpm dont i I need to go for higher rpm?
Can you help me with company name or address for upgrading the ECU for a highr RPM TO 7 OR 8.000 ?
Thank u
youwrx is offline   Reply With Quote
Old 04-20-2004, 11:07 AM   #2
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
where do you live at? I think is the states they dont get the 2.0 NA motor.
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 04-20-2004, 11:13 AM   #3
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
as far as the 03 line up goes the US had EJ25, EJ20T and EJ25T-might actually be 04's for that. What kind of car is this? just a plain Impreza?
for help on that i would say talk to a guy named Matt Monson. just drop him a PM and ask him. He know pretty much all the subaru line up. But if you are in the Us and actually have a RS and just have your engine messed up, let us know and then we can give you lots-o-help.
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-20-2004, 01:46 PM   #4
Aphex
Member#: 146
'16 WRX Limited
2.0L N/A impreza's were sold outside of the states.
I remember hearing of somebody in canada that reprogrammed a stock ecu, but I am not sure if the exact results.
do any of the piggybacks allow for rpm raising? like a unichip or something similar?
Aphex is offline   Reply With Quote
Old 04-20-2004, 02:01 PM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
The Link does. But the limits of your RPM range will be based more on what your valve train can handle.
You will probably have a serious valve float problem at higher RPM's with an N/A Subaru motor.
I would not recommend raising the rev limit above 6500 or MAYBE 7000rpm's TOPS with out upgrading your valve train. (Springs/retainers/etc)
Tats.
Tats is offline   Reply With Quote
Old 04-20-2004, 03:03 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
um, running boost dont even think about taking it to 6500 w/o valve train if ur runnin like 10 psi+
upgrading springs is easy, and relatively cheap, ~400, if i can do it, you can do it
Old 04-24-2004, 01:21 PM   #7
youwrx
Member#: 59999
wher can i gety them?
Old 04-24-2004, 01:25 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Old 04-24-2004, 06:19 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Like the others have said, unless you upgrade your springs, you do not want to bump your redline. Do a search in this forum about it. There was a long discussion we had about it when Graham was trying to decide what to do about heads on his RSTi build. Or you can just wait until totoherbs comes along and links it up for you.
Got my first CEL, stock headers, Cat, ECU - Help please Osgood30 Normally Aspirated Powertrain 3 12-16-2002 10:38 AM
ECU help NTlncer Newbies & FAQs 2 12-09-2002 08:39 PM
engine swap ECU help please! funkadellic69 Legacy Forum 0 11-12-2002 03:13 PM
Link ECU help Niloc Normally Aspirated Powertrain 6 11-01-2001 11:12 PM
Help! I need ECU HELP! mcu81 Normally Aspirated Powertrain 2 08-06-2001 05:36 PM
