Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 06-13-2000, 05:56 PM   #1
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Post bigger piston for EJ20 or EJ22.
Hello Guys:
As you know here in my place we got the EJ20 non turbo engines, actually some have been supercharged and turbocharged with 2.5 kits, this engine are EJ20 with SOHC, as 2.5 rs from 99, I`m trying to figure out if I can add some bigger piston to my block, maybe 2.2 or form 2.5, my spec. are bore 92 and stroke 75 (in mm), I got an engine completed disamble and I I saw that I have to much material as cylinders skirts, maybe if one of you tell me about 2.5 or 2.2 pistons (bore and stroke) I will know with what I can play, maybe rods and crank are the same, of course I will have to take care of compresion, but math don`t lie, and we can modify pistons structure in order to get the desired compresion... anyone knows if this is possible, for example in US cases, have you seen 2.2 ls imprezas overbored and 2.5 injectors added, without changeing crank or rods?, if 2.2 and 2.5 conserve the same block have you been told that EJ20 turbo blocks are the same, I mean in space?
DJIMPREZA is offline
oversize pistons for a 1998 ej22?? tedsan126 Subaru Conversions 4 02-04-2010 09:28 PM
Oversize pistons for a 98' EJ22 tedsan126 Built Motor Discussion 0 02-04-2010 12:03 PM
rings for os2 piston for ej20 supernick77 Private 'Wanted' Classifieds 1 06-03-2009 05:24 PM
ej20 or ej22 block? decepticon Subaru Conversions 1 04-15-2003 02:42 AM
EJ20 or EJ22 - How easy to find parts? FM2 Normally Aspirated Powertrain 8 03-11-2001 12:55 AM
