Old 04-20-2004, 06:38 PM   #1
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Default Help!!!!!! Pulled Some CELS
Can anybody help with these CELs I pulled last night?
P0420
P0172
P0107
Setup
2002 RS EJ22T with SOHC heads
Ludespeed Stage 1 with J&S Safeguard
Walbro Fuel Pump
Stock ECU
Can anybody help me remedy these things or get them cleared to get my engine running decent at idle?
I'm stupid with this J&S Safeguard and the codes pulled have either to do with misfire or timing or MAP which it all controls. Help
benjaminetanyahoo is offline   Reply With Quote
Old 04-20-2004, 06:51 PM   #2
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Catalyst System Efficiency Below Threshold
Fuel trim malfunction (A/F too rich)
Pressure Sensor Circuit Low Input
-Brett
ExecNav is offline   Reply With Quote
Old 04-20-2004, 06:59 PM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Anybody got some relatively cheap fixs for them? or Explain what I need to do to accomplish and clear those CELs? I am pretty dumb when it comes to this and learning as I go along.
Old 04-20-2004, 07:18 PM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Do you have catless pipes? That could be the P0420. A MIL eliminator will fix that. Or maybe the fact that your running rich is causing your rear O2 sensor to give you a cat inefficiency. And maybe the pressure sensor circuit low input is causing the rich conditions. What kind of fuel managment do you have? RRFPR? AFC? Anything? Maybe it just all needs to be tuned.
If you know where the pressure sensor wire on the harness is, check the voltage there. That would be a good place to start since it's basically first in line.
-Brett
Old 04-20-2004, 07:30 PM   #5
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
for the 420, do the mechanical CEL fix. Costs less than $10. Search for mechanical CEL fix and you'll find it.
For the pressure sensor input one, I'm guessing either your voltage clamp is set to high, or you have something wired wrong.
lotusTT is offline   Reply With Quote
Old 04-20-2004, 10:05 PM   #6
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Could it be too much fuel pressure overpowering the stock (?) regulator at idle? Are you running any other fuel management?
-Charlie
phattyduck is offline   Reply With Quote
Old 04-20-2004, 11:41 PM   #7
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Something wired wrong? It's running off the stock ECU
Old 04-21-2004, 12:41 AM   #8
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Yes, the J&S has a voltage clamp for the MAP sensor (assuming you have the newer version 2, which you must if you have no other management). If you unplug the J&S without reconnecting the wires to the ECU, the car won't start.
Old 04-21-2004, 01:14 AM   #9
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I have the newer version 2 and I am looking at the diagrams right now for it. I understand the whole unplugging and needing to replug it in back to the stock ECU.
I have noticed that when I get into the gas I hit the MAP Limiter light and just from reading and tyring to learn that is tried to the voltage clamp correct?
Second the J&S has a built in voltage clamp, where can I change the setting on this to properly turn it to not hit the MAP Limiter light? The turn button right underneath it I assume, just want to make sure.
Old 04-21-2004, 01:43 PM   #10
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Screw it I will just find a Link Plus and sell this piece of junk.
Old 12-12-2004, 04:12 PM   #11
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
any other info on the p0107? im trying to figure that one out on my own car right now.. i have a UTEC
jared nelson is offline   Reply With Quote
Need help pulling CEL code rob North West Impreza Club Forum -- NWIC 3 09-23-2003 03:26 PM
Help w/some CELs... Hassassin Tri-State Area Forum 14 09-10-2003 12:43 AM
help pulling CEL code in San Diego JohnW Southern California Impreza Club Forum -- SCIC 2 02-07-2003 01:04 AM
Need Help Pulling CEL code cvsinner Bay Area Impreza Club Forum -- BAIC 4 04-04-2002 10:51 PM
Need help pulling CEL code Senger Bay Area Impreza Club Forum -- BAIC 2 03-01-2002 03:01 AM
