Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 04-20-2004, 11:35 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default Supra TT side feed injectors
Is there a write up anywhere on how to mod them to fit into the 98rs?
NeaD is offline   Reply With Quote
Old 04-21-2004, 07:10 PM   #2
NeaD
Member#: 43371
Hydra User, Blue
anyone know?
Old 04-21-2004, 11:35 PM   #3
Darshu
Member#: 1676
98RS w/ EJ207
2010 Mazdaspeed3
USDM 550cc Supra TT side feed fuel injectors don't fit in any side-feed fuel rails that Subaru makes. I've personally tried them in MY98 RS and Legacy Turbo rails. No dice. Try some yellow-top Nismo 555cc injectors instead, or be prepared to chop apart a stock Supra rail for the injector bosses and build your own custom rails.
Also, you'd need ballast resistors for Supra injectors since they're Low-Z and your Subaru uses High-Z injectors.
Darshu is offline   Reply With Quote
Old 04-22-2004, 12:06 AM   #4
NeaD
Member#: 43371
Hydra User, Blue
Yellow-top Nismo 555cc injectors sounds fine then.. thanks for the info.
My sti yellow side feed 550cc injectors for your smaller side feed injectors president_douche Engine/Power/Exhaust 7 02-12-2012 05:01 PM
WTT: PA: PE850cc Side feed injectors for stock side feed injectors + $100 wkderf Tri-State Area Private Classifieds 7 09-19-2010 09:17 PM
sti yellow side feed injectors, oem td04 turbo, oem wrx top feed injectors, etc. arrowscooby Engine/Power/Exhaust 57 06-25-2009 10:06 PM
WTT My stock yellow side feed sti injectors for your stock wrx side feed injectors president_douche Engine/Power/Exhaust 2 05-17-2009 12:42 AM
Perrin Side Feed Fuel Rails and Perrin Modded Side Feed Injectors SloRice Engine/Power/Exhaust 7 04-26-2007 02:49 PM
