Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-20-2004, 11:38 PM   #1
MattDell
Member#: 16803
Default "Play" in the steering wheel
What causes it, and how can it be fixed?
-Matt
MattDell is offline   Reply With Quote
Old 04-21-2004, 12:01 AM   #2
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Usually a loose nut behind the wheel
There's alot between the wheel and the tires, power steering pump, belt etc.
Also tire size, pressure...
BlkTS02 is offline   Reply With Quote
Old 04-21-2004, 12:25 PM   #3
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
I would think this should be in Brakes & Suspension but there are several parts that can contribute to 'play'.
Front endlinks, do you have solid ones? Stiffening these up can really liven up turn in, especially if the stock pieces are worn at all.
Get urethane steering rack inserts, these supposedly really firm up feel, haven't done these on my car but it makes sense.
Anti-Lift kit will stiffen things up as well, especially if you get a kit with spherical bearings like Perrin.
Tires, get something with a stiff sidewall like Azenis.
Compressed is offline   Reply With Quote
Vibration when on the brakes, in the steering wheel too. motogp125 Brakes, Steering & Suspension 5 09-12-2005 06:32 PM
"Scraping" Noise In The Steering Wheel! Ramon_12345 Brakes, Steering & Suspension 2 08-05-2005 12:07 PM
"Scraping" Noise In The Steering Wheel! Ramon_12345 Normally Aspirated Powertrain 2 08-02-2005 03:58 PM
Vibration in the Steering Wheel at 80+ after Maintenance porque Newbies & FAQs 5 08-28-2004 08:01 PM
Horn switch in the steering wheel? Uncle Scotty Interior & Exterior Modification 6 05-16-2004 10:12 AM
