Old 04-21-2004, 12:48 AM   #1
Aus_RS
Member#: 35441
02 RST
GT2540R
Default Experience with stock MAP sensor?
I got the part number off the stock MAP sensor, and found the datasheet for the part (www.datasheetarchive.com is a very handy site). I've posted the relavent bits here
What I'm wondering is, does the sensor really do what it shows in the datasheet, i.e. the output flattens after about 4.7 volts (~17.7PSI). If that were really true, then people wouldn't be needing 4.7V zeners or other clamps to prevent high MAP pressure CELs, right? Maybe the datasheet just shows the guaranteed linear section or something like that?
Has anyone seen what the stock sensor does in real life at higher pressure?
Cheers,
Mark.
Aus_RS is offline   Reply With Quote
Old 04-21-2004, 01:34 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
From what I've heard, the output above 4.7-4.8v is very erratic as it's the very end of the ability of the sensor. I don't think it just flattens out as pretty much everyone has proven that it does go above that certain voltage (by needing to use voltage clamps).
Old 04-22-2004, 08:06 AM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Default Re: Experience with stock MAP sensor?
You have to realize that P2 is most likely absolute pressure, which corresponds to only about 2 psi of boost.
Also, the graph is a generalization of the MAP sensor response curve. Although actual sensors have guaranteed response for linearity and accuracy in the P1-P2 range, nothing is guaranteed beyond those specified limits of operation. Subaru took care of this by implementing a voltage limit interlock (there's probably a CEL if the voltage went below ~0.3V too).
-WaC
Wayne
wac is offline   Reply With Quote
Anyone have experience with P0325 Knock Sensor? kaoz Vancouver Impreza Club Forum -- VIC 11 05-31-2008 04:19 PM
STI UTEC with TXS map sensor and map switch bgod Engine/Power/Exhaust 3 09-06-2007 11:22 PM
Anybody have any experience with DEI motion sensors? hector Car Audio, Video & Security 8 03-25-2007 01:34 AM
Someone please confirm... Stock MAP sensor limit? fc3swrx Engine Management & Tuning 0 06-13-2004 02:12 PM
stock map sensor? Midwayman Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-07-2003 11:39 PM
