Old 04-21-2004, 09:35 AM   #1
dcoty
Member#: 3149
01 V7 GC/R32 sky
Default Need an oil cooler for my car...help please!
Hey guys,
it seems that I need an oil cooler for my car to be on the safe side when i track it, the only problem is...I dont know where to start for this one.
Does anyone know a place that sells an oil cooler kit or a place that could scource all the parts? Any suggestions welcome!
Dan
dcoty is offline   Reply With Quote
Old 04-21-2004, 10:12 AM   #2
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '99 SF Fozzie
Get the oil cooler setup from a '91 Legacy Turbo, you'll need: Water pump, Oil Cooler and a few hoses and things all from a '91 EJ22t but it will be a fairly easy and effective install.
Here's a pic to give you an idea of what it looks like:
The oil cooler attaches where the oil filter goes (oil filter then attached below the cooler), the line around the front of the block provides the coolant flow from the water pump that has a hose outlet on the left for this setup. There is also a hose that comes out of the back of the cooler and you'll need the nipple that screws into the block to attach to complete the coolant flow.
Opie is offline   Reply With Quote
Old 04-21-2004, 11:13 AM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
look in the forester accessories manual from the gen1's
(that will help u avoid needing the water bump)
YaZahX is offline   Reply With Quote
Old 04-21-2004, 12:29 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You can buy the oil cooler kits from dealers that are made for your car.
Tim Sanderson is offline   Reply With Quote
Old 04-21-2004, 12:49 PM   #5
dcoty
Member#: 3149
01 V7 GC/R32 sky
Thanks guys, I was looking for an air to oil thermostat regualted oil cooler and I found out that they come on the STi's (according to the place). The responses were super helpful! I was just looking for personal opinions on setups and how people liked them.
Opie- Thanks for the pic and details, it helped me out, also it helps for the install a bit too.
Thanks guys!
Dan
Old 04-21-2004, 01:50 PM   #6
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Dcoty,
One of our Ottawa members was selling an STI one... that was on Ver7 engine.... (till he sold the engine).....
He had posted:
front mount oil cooler 17" x 5" x 1.5", came with adaptors and hoses, average 20 to 30 degree lower than stock oil temp
I'm not sure if it's still for sale but he was asking $300....
Here's a pic:
Robin
Robin2 is offline   Reply With Quote
Old 04-21-2004, 02:17 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That is a very trick set up.
Old 04-21-2004, 04:02 PM   #8
Section 8
Member#: 821
Get a MOCAL thermostat, put lines from where you decide where you want to draw oil from (sandwhich adapters are good for this), and use an external cooler. I wouldn't use the engine's cooling capasity to also cool the oil, particularly one where RPMs are elevated (more engine speed is more friction, thus more heat). THe cooler the coolant going into the engine keeps vapor blanketing to a minimum. It usually helps to know your oil temperature beforehand to determine the correct size core for cooling. If you get on that is to big, your thermostat will be opening and closing sending over cooled oil back to the engine on ocasion, and one that is to small your temp will not drop enough.
It is better to get one that is a *little* to big rather than to small. You can always block a portion of the cooler to reduce effectivness, or reduce the ammount of frontal area by turning it to an angle instead of directly facing the airflow. Trying to increase the efectivness of a cooler to small is futile. Of course larger coolers are more expensive. You do not have to purchas an Earls cooler, or Aeromotive ect, there are plently of other brands that are less expensive that cool well. You may need a slightly larger cheaper cooler, but they generally weigh the same or less, and you won't feel so bad when it eats a rock or 10.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 04-22-2004, 04:47 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I have a Mocal cooler and sandwich adapter (with built-in thermostat) on my Mustang. The car has not seen track time yet, but I consulted with a couple of shops to figure out which size to go with. Based on their recommendations, I went with a 25-row 235mm wide Mocal cooler. We shall see if that's sufficient. This is on a naturally aspirated 357ci (iron block, aluminum heads) that should put down around 450hp (mmmmmm, cubic inches....), so that gives you an idea of cooler sizing. The guy who built the engine and did most of my Mustang's set up for me didn't think the cooler would be big enough, but I've talked to guys running similar combos that have no problems, soooo....
Try talking to the guys at www.batinc.net - they were pretty helpful when it came to questions about sizing the cooler.
I'm not sure they make one for Subaru fitment, but Mocal makes a couple sandwich adapters with the thermostat built in. Makes hose routing a helluva lot easier (and cheaper - fewer hose ends to buy). BAT, Inc's website didn't show the sandwich adapter I bought, but it is available.
Pat Olsen
'97 Legacy 2.5GT sedan
PS - A significant portion of your cooler budget will be good braided lines and hose ends. It adds up pretty quick. On the Mustang I use -10AN hose - the smaller Subie motor could probably get away with -8AN. For a track car, braided lines are a must, so don't cheap out on "normal" rubber lines. Most of the "universal" oil cooler kits (like you would find from Summit, Jegs, JC Whitney) use rubber lines, not braided stuff. You don't want to endanger yourself or someone else on track by having a rubber oil hose rupture on track.
Old 04-22-2004, 02:31 PM   #10
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
beware.....I had an OEM subaru oil cooler off of a forester. The problem was the oil cooler drops the filter 5-7 inches lower so now the filter was sitting .001cm's away from the header. I had the borla header wrapped and it worked fine, but you couldnt unscrew the filter. I took off all the wrap so I could change my oil without any problems and the heat generated from the header would melt the oil filter (defeating the purpose of the oil cooler) after 2000 or so miles.So I just returned it back to the stock filter. I have everything sitting in my room at home if you want to buy it. I wont be able to ship it till after may 7 though (I'm at college)
AustinSTi is offline   Reply With Quote
Old 04-22-2004, 06:55 PM   #11
2RS's4US
Member#: 54263
2001 BRPAVOTWE4EAT
I am svxr8dr
I may be interested in buying your kit, how much do you want for it?
2RS's4US is offline   Reply With Quote
Old 04-22-2004, 07:43 PM   #12
dcoty
Member#: 3149
01 V7 GC/R32 sky
Wow, tons of helpful replys, thanks guys!
Robin- I might be getting one of a V8 STi, but if it falls through, il look into the one you mentioned, thanks for including the pics too.
Austin- You dont think i should go with an OEM one? Sounds like yours was pretty problematic (enough to switch back to stock). Im going to ask about that placement, thanks for the heads up.
Really appreciated everyone!
Dan
Old 04-22-2004, 10:19 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
Austin,
Which headers do you have on your car? I ask because it will make a difference. My Cobb headers don't even come close to the oil filter, so OEM may be an option for me as my build progresses to this point...
Old 04-23-2004, 12:30 AM   #14
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
No prob...... I was going to buy it for our rally team (Evo4) but it doesn't have the same fittings.... and it's $300CDN....
Robin
Old 04-23-2004, 01:59 AM   #15
kaos200
Member#: 2692
where can you get the mocal parts?
kaos200 is offline   Reply With Quote
Old 04-23-2004, 12:12 PM   #16
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
I have a 4th gen. Borla Header
Old 04-23-2004, 03:21 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
Try JEGS or one of the other muscle car mail order houses...
Old 04-23-2004, 03:39 PM   #18
Section 8
Member#: 821
THese guys have good proces:
Clicky
cheeRS,
Greg
Old 04-24-2004, 02:49 PM   #19
kaos200
Member#: 2692
20*1.5 thread right?
Old 04-25-2004, 12:45 PM   #20
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Yes, that is the correct thread pattern.
AJ711 is offline   Reply With Quote
Old 04-27-2004, 03:52 PM   #21
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Dcoty;
They sell 3 different oil cooler kits on this page:
http://home.att.net/~teaguesauto/motor.htm
I like the genuine Subaru kit; it seems nice and compact. I don't see why I would need one though
Hope this helps.
powerlabs is offline   Reply With Quote
Old 04-27-2004, 04:06 PM   #22
kaos200
Member#: 2692
I just ordered an adaptor and the cooler, and Ill make my own lines.
I promised myself after the last track day this would be my next mod after seeing my oil temps go higher then Ive ever seen them! (Although still in safe range)
Old 04-27-2004, 04:52 PM   #23
spiralsmurf
Member#: 16085
2005 STi
I believe rallispec used to make a kit, i have it on my RS. If you're interested Dcoty I can take some pics and you're welcome to buy it.
spiralsmurf is offline   Reply With Quote
Old 04-28-2004, 03:47 AM   #24
dcoty
Member#: 3149
01 V7 GC/R32 sky
Ill let you know, thanks, Ill see if my place up here has one, if they dont then ill send you a PM. Thanks!
Powerlabs- good link, saved it! Thanks.
Dan
Old 04-28-2004, 03:54 AM   #25
kaos200
Member#: 2692
I just realized, the adaptor may hit the damn header
anyone have the mocal adaptor without trouble?
I'm at a dead-end for an oil cooler on my '05 STI, with FMIC kc jazz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 02-16-2009 07:32 PM
Mounting an Oil Cooler in my hood scoop keirnna Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 07-29-2005 10:20 AM
I'm looking for an OIL COOLER for an 04 STi rich728 Private 'Wanted' Classifieds 1 04-07-2005 12:52 PM
Can someone teach me about oil coolers for my car STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-06-2003 04:08 AM
Should I get an oil cooler for my 1997 L with the 2.2 liter motor? dsc Normally Aspirated Powertrain 2 04-05-2002 01:37 PM
