Old 04-21-2004, 10:10 AM   #1
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
Default after being 3k over due..i did an oil change yesterday
that is all
YaZahX is offline   Reply With Quote
Old 04-21-2004, 10:26 AM   #2
ClimbinNBouldern
Member#: 50108
2000 2.5RS
BRP
your car is Grateful
ClimbinNBouldern is offline   Reply With Quote
Old 04-21-2004, 11:33 AM   #3
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
any metal shavings in the oil? (thank god for magnetic oil drain plugs)
Machine Age Victim is offline   Reply With Quote
Old 04-21-2004, 12:03 PM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
I did that with an old 86 Buick Somerset. I ran half a year without an oil change, not the best thing to do. Needless to say, it started buring a little more oil than usual after that. I'm hoping yours is at least a somewhat new Subaru. That way it's not worn enough to matter much.
It's time to change oil in my Subaru, 3k...only, lol. The oil doesn't look half bad yet, still pretty clear.
Old 04-21-2004, 12:11 PM   #5
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Probably not that big of a deal, especially if you remembered to top it off periodically. Oil can still have alot of life left after 3k, depending on driving conditions, and topping off the oil periodically can make a big difference too.
I do happen to change mine every 3k though
Compressed is offline   Reply With Quote
Old 04-21-2004, 01:20 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
According to you owner's manual you should change your oil anywhere between 3000 and 7000 mi depending on conditions. There is very little risk in running a bit longer as long as you don't run low. And if you run synth, you definitely have no issues running longer than average...
Old 04-21-2004, 02:26 PM   #7
obyone
Member#: 16523
True, but "Depending on conditions" is a very vague condition. Severe conditions can range anywhere from: Sand duneing, Arctic racing, to stop and go traffic.
obyone is offline   Reply With Quote
Old 04-21-2004, 05:13 PM   #8
nySulli
Member#: 32617
2008 STi
personally even with synthetic, i prefer to change it every 3k regardless, even if it would be good to 5k, thats still when its the least protective, fresh oil is never a bad thing
nySulli is offline   Reply With Quote
Old 04-22-2004, 12:26 AM   #9
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
conditions: beating the crap out of the dohc ej25 with 120k on the clock...
toping off: i did once when i was 1k over when i was testing the new brakes, slammed on teh brakes and the oil light came on
even better: ran an autox knowing the oil change still wassnt done
burning oil: its going some where i do know that... there are small leaks from the valve cover gasket, but it is consuming oil and my bumper is allways clean so beats me..
Old 04-22-2004, 12:40 AM   #10
ClimbinNBouldern
Member#: 50108
2000 2.5RS
BRP
do i sense that you are waiting to swap a turbo engine in...
Old 04-22-2004, 12:40 AM   #11
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
85,000 like new miles on synthetic being changed every 8k. Doesn't burn a drop.
nitrohuffer is offline   Reply With Quote
Old 04-22-2004, 12:41 AM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
I recently took my car in for it's 90k service. I do my own oil changes and whatnot, but like to have a tech look at it every 30k mi just to get a second opinion. Anyways, I tell them I want synthetic and they ask how many miles since the last change. I tell them 3500. He tells me I could save some money on oil if instead of changing the oil every 3000-3500 mi, just change the filter. He said synth absolutely does not break down in less than 7000 and the important thing is you keep it clean. Now with 97k mi on the car, I figure, what the hey. It might be different if I wasn't getting a new shortblock by 120k, but until then I will be changing my oil every 7000 mi with a filter change every 3500...
So yesterday i got an oil change at dulles motorcars Un0RiGiNaL Mid Atlantic Impreza Club -- MAIC 21 01-16-2009 11:19 AM
Smoking after an oil change? Kiwi Service & Maintenance 18 07-27-2007 05:55 PM
How critical is an oil change every 3K miles? jetfan2207 General Community 11 06-19-2007 01:23 PM
a little over due for an oil change BlackoutWRX Newbies & FAQs 16 04-16-2005 03:40 PM
why is my car slower after an oil change? SLowery Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-09-2002 08:55 AM
