Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-27-2000, 02:11 PM   #1
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Question RedLine Water Wetter??
Anyone use this...does it really do anything??
donjuan is offline
Old 09-27-2000, 02:51 PM   #2
N/A
Member#: 133
TBA TBA
TBA
Post
I used it in the Primera after it got wrecked but as far as a difference goes I couldn't notice anything. Then again a butt dyno isn't that accurate and since the car was sold I will never know if it effected the long term condition of the radiator or engine. Redline sells some tested and high quality products so its probably worth the money.
N/A is offline
Old 09-27-2000, 02:55 PM   #3
roninscar
Member#: 2306
2000 RS Sedan
Blue Ridge Pearl
Post
I used it in my FZR1000, and it seemed to help keep the temp a little cooler. Not a power gain issue, more of a keeping things from getting too hot, issue.
Regards,
scotto
roninscar is offline
Old 09-27-2000, 04:06 PM   #4
ballistic
Member#: 2163
Post
yep run it in my moto-x bike was having cooling problems when riding the dunes. this stuff really works to help cooling what it dose is reduce the surface tension of the coolant this makes it transfer heat more efficiently. Dan
[This message has been edited by ballistic (edited September 27, 2000).]
ballistic is offline
Old 09-27-2000, 04:19 PM   #5
Tim K.
Member#: 214
2014 Massey Ferguson
Red
Post
We used it in our race bikes. Glycol is a big no-no on the race track. It doesn't evaporate quickly and is very, very slick. If you leak it, bad things happen to those that have to run through it. The Water Wetter was allowed (not glycol based) and helped lower the bike's water temp. Its a good product, but I don't know if its necessary for everyday street driving.
If your stuck in Texas though, every little bit may help.
Tim K. is offline
Old 09-27-2000, 05:09 PM   #6
Joel Gat, 1.8L
Member#: 32
Post
Hello,
It works pretty good for track days in cars, too I'm gonna use some at t-hill tomorrow. Should be interesting, with 2 drivers, the car will see six (6) solid hours of track time...
Joel - testing out the limits of water wetter!
Joel Gat, 1.8L is offline
Old 09-27-2000, 05:35 PM   #7
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
Its the wettest of wet water. Plus... it cools better too.
Rich L is offline
Old 09-27-2000, 06:14 PM   #8
Gerry
Member#: 1829
Post
Use it in all my cars and the bikes. It's probally one of the best products i've used. I mean it lowered the temp on my tl1000r which idles @ 190 degrees. Let me tell you that few degrees difference makes my jewls very happy =0)
Gerry is offline
Old 09-27-2000, 09:09 PM   #9
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
We do a lot of off-roading up in the stix. Take a large V8 and shoehorn it into a Jeep and you're bound to get some heat issues. Helped drop the temp down about 15-20 degrees F from what it was running at.
Fitz
Fitz is offline
Old 09-27-2000, 09:50 PM   #10
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Does one have to flush out the old stuff before putting in the Water wetter? Or can I just put it in with the existing coolant? Also, I'm thinking of going with the stuff that Royal Purple has since I'm already running royal purple oil. Anyone have experiences with that?
Keiho is offline
Old 09-28-2000, 03:17 AM   #11
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
Water wetter can be added to your existing coolant.
Fitz
Fitz is offline
Old 09-28-2000, 03:28 PM   #12
RichXKU
Member#: 895
2005 WRX STi
CGM
Exclamation
Some ClubSi members have noted gummy brown deposits in the coolant reserve tank when the engine is cool. This doesn't affect cooling, but.. who wants things floating in their water?? This may have something to do wiht the factory honda coolant though.
Rich Mazzeo
'99 Civic Si
RichXKU is offline
Old 09-28-2000, 04:26 PM   #13
Tim Prudence
Member#: 216
Post
Water wetter will turn your coolant brown, I've never seem any gummy deposits though.
Tim Prudence is offline
Old 09-28-2000, 05:49 PM   #14
ballistic
Member#: 2163
Question
dont think i have ever seen it turn the coolant brown before i wonder if its a bad reaction to a spacific kinda antifreeze or something?
Old 09-29-2000, 05:08 PM   #15
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Post
I added a bottle to the cooling system on my ancient ('83!) Starion Turbo which tends to run hot.
It doesn't run hot any more.
Recommended.
Ken Levin is offline
Old 09-29-2000, 05:20 PM   #16
Tim Prudence
Member#: 216
Post
I think it's because bluish green coolant + pinkish purple water wetter = brown.
That's what I found. The car did run noticeably cooler, which is not always a good thing (though it is when you have a turbo).
how much redline water wetter do you add? M32WRXin3seconds Newbies & FAQs 11 02-02-2004 06:07 PM
mixing Redline Water Wetter wrx2sti Service & Maintenance 11 11-02-2003 08:31 AM
Redline Water Wetter Snitt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-02-2003 11:56 AM
Redline Water Wetter? impreza2002 Normally Aspirated Powertrain 8 03-23-2003 01:04 PM
How many guys running Redlines Water Wetter? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-28-2002 09:23 PM
