Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-21-2004, 03:31 PM   #1
animosity
Member#: 59395
2007 2.5 RS Wagon
Crystal Gray Metallic
Default check engine light
well i bought a 2000 2.5rs the other night and so far im lovin it
went to show it off to a few friends but filled up the tank first on the way home an hour or 2 later the check engine light came on so i busted out the owners manual and it said could be emissions control or the gas cap called the dealership they said give it a few days
so guess my question is is this a normal thing that happens after fillin up the tank 3 or 4 clicks of the cap is enough isnt it
animosity is offline   Reply With Quote
Old 04-21-2004, 04:33 PM   #2
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
Gas cap is a common CEL trigger. Just make sure you have it on good and snug. If the light doesn't go off, you can disconnect the battery for several minutes and it should reset.
NotAnRS is offline   Reply With Quote
Old 04-21-2004, 06:09 PM   #3
Julian
Member#: 1182
MY00 RS
BRP
This isn't normal after filling up the tank. And three or four clicks is enough to prevent that particular CE code.
If you have an Autozone nearby, they also pull codes. Can't do anything about it until you know what it is.
Julian is offline   Reply With Quote
Old 04-21-2004, 07:02 PM   #4
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Well, you didn't say what octane gas you got versus what was in the tank, but most likely it's the gas cap. Yeah, 3-4 clicks SHOULD be enough, but on my wife's OBW I have had to learn to LEAN against the cap and click it 15-20 times to keep the damn CEL away!
1 Lucky Texan is offline   Reply With Quote
Old 04-21-2004, 07:48 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
did you fill it up while the car was running?
if so, thats probably why the light is on. Always turn the car off when you are getting gas.
Jay
Old 04-21-2004, 08:12 PM   #6
obyone
Member#: 16523
this anymore???
Jay
Don't leave it on the A/C position either.
obyone is online now   Reply With Quote
Old 04-21-2004, 10:57 PM   #7
SjYankee006
Member#: 33943
It's probably the gas cap. I get that CEL from time to time after filling up, so often that I'd almost call it normal. I'd get the code pulled though, just in case.
SjYankee006 is offline   Reply With Quote
Old 04-22-2004, 12:20 PM   #8
gixxerg1
Member#: 34957
2003 wrx
mbp
would it automatically go on right after you just filled it with gas or after like say 20 miles?
gixxerg1 is offline   Reply With Quote
Old 04-22-2004, 04:31 PM   #9
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Time to replace your gas cap.
never had that problem. I leave the radio on while pumping in the summer. It's fine.
I will go out after 3-4 successful trips. A sussful trip is defined as a complete warm up / cool down cycle without the error occuring. So, if you drive it on 3-4 seperate ocasions with it fully cooling off, between drives, it should clear.
AO
m750 is offline   Reply With Quote
Old 04-22-2004, 07:08 PM   #10
animosity
Member#: 59395
2007 2.5 RS Wagon
ok went to an autoparts store today and had em read me the code it was p0420 which turned out to be a problem with the catalyste converters so i guess ill go back to the dealership sometime next week ;x
Old 04-22-2004, 08:04 PM   #11
Julian
Member#: 1182
MY00 RS
BRP
Ahhhh, P0420, we know it well.
Do you have a header or exhaust system on the car?
If bone-stock, your emissions system needs work. Less than 80K miles and the dealer should warranty the work, if your car is stock.
Old 04-23-2004, 12:02 AM   #12
incognito
Member#: 12952
2011 STi
yes dont leave the air conditioning on! it will drain your battery.
*cough* ACC position *cough*
and yes leaving the car in the ACC positin can also cause the code to be set.
it can come on right after, or it can come on 3 weeks after.
incognito is offline   Reply With Quote
Old 04-26-2004, 05:07 PM   #13
animosity
Member#: 59395
2007 2.5 RS Wagon
im pretty sure its all stock the dealer didnt tell me anything was modded on it and i didnt think to ask but yeah the mechanic said if its under 80k its still under warranty yay
Old 04-26-2004, 09:01 PM   #14
obyone
Member#: 16523
this anymore???
...smart ass.
But I had to admit, you got me there.
Old 05-08-2004, 11:17 PM   #15
animosity
Member#: 59395
2007 2.5 RS Wagon
well the problem with the catalyste was fixed.. i think ;p
the mechanic didnt put something back on right or didnt put something back on at all and now my car sounds like a lawn mower when im movin along and sounds like its about to explode when i rev it up :>
have to drive back out the dealership on monday to have em fix it
Old 05-09-2004, 12:03 AM   #16
animosity
Member#: 59395
2007 2.5 RS Wagon
ok another quick update i got under the car and was lookin around it seems that where theres a split in the exaust under the engine before it goes to the cc the gasket thats there is either blown or not set right but either way it was working perfectly ok until i left the dealership parking lot
now i wonder if theyre gonna try and charge me for that
and i forgot to mention everytime i let off the gas my car kind of makes a gurgle sound since this little problem friend said its becuase its sucking air back into the engine ;/
any thoughts/input
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 04:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 01:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 10:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 03:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 08:50 AM
