Old 04-21-2004, 04:42 PM   #1
2.5racer
Member#: 12482
2000 RS w/ej20 & e85
94 RX-7 1/2bridge w/meth
Default sti bottom end
so heres the thing... I'm not planning on doing anything untill I pay off my car at the end of the summer, but I was looking at some options for some more power. First came the thought of turboing my rs.... then I thought about a wrx swap... then I thought I'd rather have a j-spec sti version 3 now I'm wondering about something.
I think I heard of a few people doing a build up useing the sti shortblock on 2.5rs heads then useing like a ludespeed turbo kit and blam a reliable 15+psi engine that has TORQUE (with engine management and fuel mods) does that sound right?
is there more than... parden my french... slapping the 2.5rs heads on the bottom end of the sti block... I'd probably get some other things while I was at it like stronger valves and springs, maybe turbo cams... anyhow you get my drift ... as bare minimum for the block and heads will they work together?
2.5racer is offline   Reply With Quote
Old 04-21-2004, 04:45 PM   #2
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
I have this swap on my 00RS. Everything bolts right up, as if it were "meant to be". It is true that you can run 15psi on this motor with the right fuel, and management etc..
Pi7467mp is offline   Reply With Quote
Old 04-21-2004, 04:48 PM   #3
2.5racer
Member#: 12482
thank you god..... I'm so glad to see people have tried this.... how do you like the setup? and how much did it cost you (I can do all the labor, and I have access to my dads shop with lifts, all tools etc.)
Old 04-21-2004, 05:14 PM   #4
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
when you do the STi block do you have to do pistons too crank or anything with it? If not what kind of CR are you running stock RS pistons and STi block?
squirrelmasta is offline   Reply With Quote
Old 04-21-2004, 06:21 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
the sti shortblock already comes assembled so you dont have to do any of that stuff. already has, pistons, crank, etc.
i think people are getting around 8.0 CR with SOHC heads, at least i know thats what graham got with his cometic gaskets and hybrid.
Old 04-21-2004, 07:12 PM   #6
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Has anyone tried this with the 98 DOHC heads yet?
NeaD is offline   Reply With Quote
Old 04-21-2004, 07:12 PM   #7
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
The setup is awesome you get the whole package for 1400 instead of 3000 if you were to peice everything out your self.I have 8.0 compression as stated above.
Old 04-21-2004, 08:11 PM   #8
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
spend the extra money and get the big port and polished dohc sti RA heads. Your motor and turbo will thank you.
Then u can go past 6200 rpms too
ImprezaRSfan! is offline   Reply With Quote
Old 04-21-2004, 10:38 PM   #9
squirrelmasta
Member#: 33445
Cherry Red
that crank and piston's are cast correct? semi closed block and everything will work on both phase I and phase II engines?
Old 04-21-2004, 11:20 PM   #10
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
yes..
Old 04-22-2004, 12:13 AM   #11
2.5racer
Member#: 12482
man this is sounding great.... pi what part of colorado are you in... cause I'll be in colorado from saturday the 24th untill friday the 30th... I'm going out there to get my subie back from my brother... long story... I'd love to stop by and see your setup... and maybe get a ride in it.... i'll be in lakewood the whole time but i'll drive a ways to see that setup.... plus I have to go north to get back to oregon anyways....
Old 04-22-2004, 01:20 AM   #12
PHATsuby
Member#: 13617
2001 Legacy GT back
It is my understanding that the SOHC ports are even larger than the DOHC, and still outflow even the RA heads.
Graham is revving to 7k with no problems so far on stock heads.
if you wanted to be totally sure then spend another 600 and do cams and springs and retainers, 7k with no worries there.
Ben
Old 04-22-2004, 11:16 AM   #13
squirrelmasta
Member#: 33445
Cherry Red
What actually determins your red line though? Head's, cams, or ECU? Ecu i'm assuming is the actual thing that cuts the power and going over the Rev limit can damage parts. so on the stock heads won't that hurt something? 6250 stock RS rev and i would love 7Grand rev so i could pull 3rd to 90 just like a W or close to it.
-Eli
Old 04-22-2004, 11:19 AM   #14
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
ecu determines the point. It basically just cuts fuel off at this point. I don't know of any electronics that will just increase the redline, but I do know that you have the ability to do this with a stand alone...Im sure you knew that.
Old 04-22-2004, 11:21 AM   #15
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Does any know the CFM for the RA heads?
seven881 is offline   Reply With Quote
Old 04-22-2004, 04:06 PM   #16
ehlpitel
Member#: 56299
1987 BMW E28
535i
most software lets you set the redline
ehlpitel is offline   Reply With Quote
Old 04-22-2004, 04:19 PM   #17
MeshmeZ
Member#: 58908
'07 STI
This is kinda hard to answer, it really depends why the redline was set at 6250. if there was problems with rods breaking by reving higher then the head might be fine to who knows what rpm.
i have also heard that the stock engine loses power over that rpm anyway, so maybe its just set there because the stock engine cant perform well above that.
like PHATsuby said, throw in a couple hundred dollars more to rebuild the head and you should be good. you would probably want to do that no matter what if your car has any kind of high mileage (dont know how many times the car has made the Colorado-Oregon trip ).
MeshmeZ is offline   Reply With Quote
Old 04-22-2004, 05:23 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Marc Rameriz, aka Xephyr is running that set up. He has had it in for a couple months now. He doesn't post here to much anymore, but is around on occasion. He was one of the first to use the EJ22T block, along with Joe Cox. Check in the Proven Power or the RMIC forums and you will see details on his 381whp dyno run.
According to Marc, he is sold on the EJ257 shortblock, and just finished selling off his EJ22T blocks and is starting to build another EJ257 based engine...
Old 04-22-2004, 05:30 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
No he's not. He took Marc's advice and upgraded the springs. The limiting factor on both the DOHC and SOHC EJ25 heads is spring tension. Above 6500rpm or so you get valve float. There is no need to port these heads. There is no need to replace the cams. Just spend the money on springs and retainers and call it done. As I said above, Marc hit 381Whp on an EJ257 bottom end with DOHC EJ254 heads with just a spring upgrade. He has a set of ported heads he has used, but prefers the unported ones because they come on power a little earlier and provide a flatter power curve. The ported heads are more peaky...
Old 04-22-2004, 06:02 PM   #20
2.5racer
Member#: 12482
the car has made 1 trip from oregon to colorado this time last year... now it's comeing home and this buildup is sounding better and better.... how much were the valves springs and retainers?
FS: 2007 STI - bottom end (assembled); top end (heads/cams assembled) squashman Engine/Power/Exhaust 11 06-06-2008 02:01 AM
Another WRX head/STI bottom end hybrid thread Carlito2002WGN Built Motor Discussion 11 04-21-2007 03:11 AM
Any problems w/ STi bottom end on '02 WRX? snarlingbeast Subaru Conversions 6 03-24-2006 02:07 PM
ordering jdm sti bottom end, and have questions?? werkInProgress Subaru Conversions 4 12-05-2004 09:04 PM
wrx tranny, and sti bottom end bryan carbon Private 'For Sale' Classifieds 7 08-10-2004 08:28 AM
