#1 |
Member#: 54322
I need some suggestions about my 93 1.8L that is hesitating, and popping at low rpms of 1k-2k. It seems when I'm not heavy on the gas it will not hesitate as much and sometimes will disappear. When I'm heavy on the gas, I get a huge loss of power from hesitation and some popping sound near the cat.(probably destroying my cat) But after the engine revs higher then 2k, the hesitation stops.
No CEL has come on. The only mod I have is a generic cone intake filter. I have new wires and new bosch platnium spark plugs. I've read another thread that Subaru's don't like bosch plugs...has anyone had hesitation due to bosch plugs?(hard to believe it's the cause) I've cleaned and checked the IAC and PCV which seem to be good. What should the resistance range on the coil pack be? I'm planning on checking the o2 sensor but I'm thinking it's not the problem since a CEL didn't come on. Anyone have some ideas on what else to check? Any info or suggestions would be greatly appreciated. Thanks in advance
#2 |
Member#: 11808
Typical of an engine running very lean fuel mix. Dirty injectors, fuel filter, fuel pump regulater and last but not least induction air leak like a vacume hose of or intake manafold gasket or ???? EdHayes
#3 |
Member#: 44887
NESIC
Vehicle:00 GC6 Silver |
yes it definitely sounds like a lean condition. Have you checked your plug wires? You mentioned they are new but are they frayed at all? You may want to make sure all the plug boots are completely dry from any water that may have got in there and make sure the boots are on tight. Also check the coil for any water.
#4 |
Member#: 54322
Thanks guys for the suggestions. I'll be checking on those items this weekend. The fuel filter was change about a year ago.
Wires are not frayed and the sparkplug boots are clean, dry and nice and tight. Anyone know what the resistence range for the coil pack is? Thanks again |
#5 |
Member#: 29961
South East
Vehicle:2008 BMW 328i Conv. 2001 Kawasaki ZR-7S |
it's your front O2 sensor, you should be throwing a CEL tho
#6 |
Member#: 54322
I was thinking its the o2 but like I said I didn't get a CEL. I will be checking that this weekend also. I really wish the car would throw a CEL so I could have something to go by.
#7 |
Member#: 3987
Vehicle:1999 Miata Black |
I had the same problem in my 2001 2.5rs exactly except instead of 2000 rpm I had to go up to 3000rpm before it would drive normal, and it would STILL not accelerate like it used to.
Swapped the O2 sensor last weekend. Car is driving like it used to. ![]() btw, I was not getting a check engine light for the O2 sensor |
| Thread Tools | |
| Display Modes | |
| 08 2.5i AT pinging at low RPM when warm out... normal? | SportshiftedSSM508 | Normally Aspirated Powertrain | 73 | 11-23-2010 09:48 PM |
| Knock at low RPMs and load | fenix-silver | Factory 2.0L Turbo Powertrain | 13 | 05-17-2010 12:51 PM |
| Knock at low rpm and throttle | PharmCo | Factory 2.0L Turbo Powertrain | 4 | 02-02-2004 10:28 PM |
| ('93-'01) Little ratling at low rpm. Opinions? | tonytiger | Impreza Forum | 8 | 06-14-2001 09:29 AM |
| Car "stutters" at low rpm | smallschip | Newbies & FAQs | 10 | 03-09-2001 12:22 AM |
