Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 02-17-2000, 07:18 PM   #1
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Question Installation of Rear Strut Tower Brace
I am planning on purchasing the Cusco Rear Strut Tower Brace. I was just wondering where it goes and what is required in installing it?
Jason
dyswtric27 is offline
Old 02-17-2000, 09:27 PM   #2
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
Post
You just remove the rear seats, unbolt the seatbelts, put the mounts in, bolt them down (15ft/lbs) and then pop the trunk (don't forget to replace the seatbelts and the rear seats and then bolt on the rear bar portion, torque to 15 ft/lbs and there ya go!
Phil
Scoob_13 is offline
Old 02-18-2000, 05:58 AM   #3
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Post
I did mine 2 weeks ago, you must remove the rear seat, seatbelt tensioners and the rear deck, then you unbolt the three bolts (12mm) at the top of the struts. Unbolt the mounts from the strut bar, place the mounts on the three bolts with the hook pointing down through the hole in the body into the trunk (you may have to remove some insulation to open up the hole), then replace the bolts (12mm) and tighten to 11-15 ft-lbs. Replace the rear deck, seat belt tensioners and rear seat. Take the strut bar and bolts and open the trunk, look in the top rear corners and you will see the hooks pointing through the hole in the body. Install bar, tighten bolts and your done!
Opie is offline
Old 02-18-2000, 06:30 AM   #4
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Post
Thanks guys!
Jason
Old 02-19-2000, 12:19 AM   #5
delectron
Member#: 227
Post
Only 15 ft/lbs!? Uh oh. I put mine on and torqued the bolts down as hard as I could with a six inch socket wrench, in fact, it probably should be done that way to properly secure the struts in the tower.
delectron is offline
Old 02-19-2000, 12:35 AM   #6
Greg I
Member#: 384
2002 Acura RSX-S
Exclamation
BE CAREFUL Delectron. Those bolts are NOT supposed to be torqued down very heavily. I'm surprised you didn't snap any of them when you did your install. 15ft/lbs is probably what the manufacturer's spec is, although I've never checked. THIS GOES FOR THE FRONT STRUT TOWERS AS WELL. When I first played with my suspension in the rear I made the mistake of over-torquing one of the bolts and snapped it clean off; didn't even take much pressure.
Greg I.
Greg I is offline
Old 02-20-2000, 01:53 PM   #7
Jackie Chen
Member#: 839
Question
How do you check this-"15 ft/lbs"?
Jackie Chen is offline
Old 02-20-2000, 02:12 PM   #8
cvalle-sd
Member#: 420
2001 Cr-V
Post
You gotta buy yourself a torque wrench - INVALUABLE - and the only way to do certain things properly.
cvalle-sd is offline
Old 02-21-2000, 09:04 AM   #9
Rajah
Member#: 362
2006 WRX STi
WRB / Gold
Have a Nice Day?
delectron, 14 ft-lbs IS the spec for those tower bolts!! You better back them off! *SNAP*
Rajah is offline
Old 08-06-2000, 08:10 PM   #10
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Post
if one was to install the rear tower brace and didnt have a torque wrench.. how much elbow grease is one to use?
Orbiter is offline
Old 08-06-2000, 09:16 PM   #11
MrP0nch0
Member#: 1859
2000 2.5RS
BRP
Post
"if one was to install the rear tower brace and didnt have a torque wrench.. how much elbow grease is one to use?"
Answer : enough elbow grease to drive down to your local hardware or tools store and buy yourself a $15 torque wrench... : P
Sorry to jump on the joke but it's true... You NEED a torque wrench to do any or this stuff... just like trying to judge the tire pressures with a swift kick and a look to see if it bulges out : ) NO GOOD!
->>> MrP0nch0 <<<-
MrP0nch0 is offline
Old 08-16-2000, 12:46 AM   #12
kar250c
Member#: 1172
2000 2.5 RS Coupe
Blue Ridge Pearl
Post
Yes, but what is the improvement?
kar250c is offline
Anyone have some pics of a rear strut tower brace installed? vipernj Brakes, Steering & Suspension 3 01-23-2006 03:31 PM
installing a rear strut tower brace, not what you think. LoganG1K Car Audio, Video & Security 6 12-31-2005 10:21 PM
Rear strut tower brace install.... caryfd227 Brakes, Steering & Suspension 7 11-08-2004 06:45 PM
ok, this may sound dumb, how do you install a cusco rear strut tower brace? 1WikdWRX Brakes, Steering & Suspension 2 05-22-2003 06:14 PM
Effectiveness of Front and Rear Strut Tower Brace MY99 2.5GT Brakes, Steering & Suspension 4 03-22-2001 02:12 PM
