Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Old 04-22-2004, 12:26 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default Close loop, open loop? it means....
What does close lopp and open loop mean? Air fuel ratio? Tuning with each? It's effects?
Thanks!
FuJi
p.s. Yes, a #3000 member asking this question....
FuJi K is online now   Reply With Quote
Old 04-22-2004, 12:46 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
When the engine is running in closed loop, it is using the A/F signal from the 02 sensor to regulate the mixture. There is a feedback "loop" between the sensor and ECU so the ECU continuously makes adjustments based on the 02 data.
In open loop the 02 sensor isn't used and the ECU sets mixture based on stored maps and other sensors (coolant temp etc).
Usually open loop is used on initial start and during warmup, until the 02 sensor reaches its operating temperature and produces a signal and the engine also reaches its operating temp, at which point the switch to closed loop takes place.
Under heavy acceleration the system will generally go open loop (some vehicles may remain in closed loop).
Old 04-22-2004, 02:37 PM   #3
1DOWNCLOWN
Member#: 50287
02 WRX
good info
1DOWNCLOWN is offline   Reply With Quote
Old 04-22-2004, 04:32 PM   #4
loreley
Member#: 19905
what about the effects of having a closed versus open system? i think thats what the original poster was getting at
loreley is offline   Reply With Quote
Old 04-22-2004, 07:19 PM   #5
Chuck H
Member#: 20442
KTR tuned 2003 WRX
VF34 equipped, 270 whp
All cars come with a closed-loop system from the factory because it's the only way they can pass emissions. By constantly monitoring the A/F ratio during normal operation, they can keep emissions to a minimum and also achieve good fuel economy.
The problem is that the narrow-band O2 sensors they rely on don't react fast enough for wide-open throttle conditions and the computer wouldn't be able to react fast enough to keep the motor alive under full throttle. So past a certain throttle position, they switch to open loop and use fixed look-up tables. Those tables are usually set on the rich side, especially on turbo cars, to prevent detonation, which leads to expensive warranty repairs on pistons with holes in them.
You can get aftermarket systems that only run open loop, but they'll never be as smooth or streetable as a system that includes an open-loop mode. Because they never have a big enough map to handle all the different possible conditions the motor can encounter. But on a race car that only ever sees full throttle, that's not a big issue.
Chuck H is offline   Reply With Quote
Old 08-12-2014, 06:12 PM   #6
bluesguyej25
Member#: 296643
2008 Impreza 2.5i
SS
I have a code scanner that can monitor the fuel system for my 08 2.5i, and during live data it is showing ol -fault. Do you think that it is not sensing the ol and running in limp mode? I don't have a header. I had it tuned 3 months ago open source rr. And I cannot clear the code. Purchased a new up stream o2 sensor to no avail. Suggestions?
bluesguyej25 is offline   Reply With Quote
Old 08-12-2014, 08:06 PM   #7
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I'll fire up my Delorean and go back to 2004 to let Chuck know.
Old 08-12-2014, 08:44 PM   #8
lemming
Member#: 250066
'06 Forester XT
'03 Rustang V6T, '13 GT
It would be much more useful if you posted the actual DTC (P0-whatever) it is throwing.
lemming is offline   Reply With Quote
Old 08-12-2014, 08:59 PM   #9
nmlittlebigman
Member#: 321409
2015 WRX LTD
Maybe contact the tuner (from 3 months ago).
nmlittlebigman is offline   Reply With Quote
how the ecu works...closed loop...open loop? IllNastyImpreza Engine Management & Tuning 13 11-26-2005 05:06 PM
Closed loop / open loop controlled by throttle position sensor? boxxxer Engine Management & Tuning 9 05-16-2005 12:12 PM
Can anyone explain the 04-05 closed loop/open loop lean cond.? boxxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-11-2005 09:00 PM
Closed loop - open loop switching Ahzlon Normally Aspirated Powertrain 5 04-22-2004 04:14 PM
closed loop/open loop questions Rickyh Engine Management & Tuning 2 02-27-2004 06:06 PM
