Old 04-22-2004, 01:31 PM   #1
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
Default What's compression ratio
I'm new to car mods. Can someone please tell me what this "compression ratio" is? My 2.5rs has a higher compression ratio than the STI but have the same displacment.
I also read somewhere that different pistons for my car can raise the compression ratio from 10.0:1 to 11.0:1. Is that good or bad?
CitySubie is offline   Reply With Quote
Old 04-22-2004, 01:46 PM   #2
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
If you want to know more about how your car works, read up on www.howstuffworks.com It may not have the exact answer to your question, but a lot of general stuff is covered there.
Compression ratio is simply the ratio of the volume of the cylinder when the piston is at the bottom of its stroke to the volume of the cylinder at the top of its stroke. The displacement of the motor is the total volume swept by the piston during its travel, multiplied by the total number of cylinders. Simple, eh?
-Charlie
phattyduck is offline   Reply With Quote
Old 04-22-2004, 02:01 PM   #3
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
How can I raise or lower the compression ratio? Lower is better for turbo right?
Old 04-22-2004, 02:18 PM   #4
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
If you don't know what compression ratio is... maybe it's a bit early for you to be delving into turbos. Howstuffworks.com is pretty good
no-coast-punk is offline   Reply With Quote
Old 04-22-2004, 02:59 PM   #5
STi-Nismo Dood
Member#: 4149
MY93 ImprezaRA Sedan
GC8.6 Aspen White
i learned from there...
STi-Nismo Dood is offline   Reply With Quote
Old 04-22-2004, 06:26 PM   #6
MeshmeZ
Member#: 58908
'07 STI
there are a few ways to change the ratio. you can get low or high compression pistons. i know for hondas they sell lower compression head gaskets which basically lift the head farther off the block, i dont know if something like this is available for the subaru.
lower compression is better for turbo engines for the safety of the engine. turboing a high compression engine can put too much stress on the rods/valves/etc. because you already have high compression and then you are pumping compressed air into the cylinder
and lastly Howstuffworks.com is awesome for learning about a ton of stuff. not just cars.
MeshmeZ is offline   Reply With Quote
2.0 to 2.5 block swap, what's the ideal Compression ratio? 516_WRX_V2 Factory 2.0L Turbo Powertrain 13 10-25-2003 12:44 AM
What's my compression Ratio now? yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-06-2003 07:35 PM
('93-'01) what is the compression ratio on a... wop Impreza Forum 9 06-15-2001 05:34 AM
Boost and compression ratios 98mpreziveRS Normally Aspirated Powertrain 4 03-29-2001 06:58 PM
Compression Ratio for 98-01 RS Delhi Normally Aspirated Powertrain 4 03-14-2001 03:00 PM
Message Board Statistics All times are GMT -4. The time now is 03:59 PM.
