Old 04-22-2004, 03:10 PM   #1
Scooby Freak
Member#: 40751
'94 SER
Default SO4 Hoosier Sizes
The SO4's aren't the same sizes as the SO3's.
Do you think the A3SO4 205/45 - 16 is a good substitute for the A3SO3 215/40 - 16?
edit: I guess this would be more appropriate in the tires forum.
Scooby Freak is offline   Reply With Quote
Old 04-22-2004, 03:24 PM   #2
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
This is a good forum becuase it's a motorsports tire.
S03 215/40-16
Tread Width: 8.5"
Section Width: 9"
Diameter: 22.7"
S04 205/45-16
Tread Width: 8.1"
Section Width: 8.6"
Diameter: 22.8"
The only thing you have going for the s04 over the s03 in the two sizes you mentioned is the new compound. You'll have less contact to the ground as the 205/45-16 s04 is a narrower tire, and also just marginally taller, so you lose a smidgen in gearing.
--kC
KC is offline   Reply With Quote
Old 04-22-2004, 03:46 PM   #3
Silver Bullet 02
Member#: 37486
Default Re: SO4 Hoosier Sizes
Considering its the only S04 tire that gives you the great gearing advantages of a 23" tall tire I would say its a much better choice than the wider size that has a larger diameter. Getting the car an inch lower to the ground with less weight and less unsprung weight is a good advantage too. The gearing advantage is the best benefit of all though. (I'm assuming you are running the stock gear ratio's and not the RA gearset)
Silver Bullet 02 is offline   Reply With Quote
Old 04-22-2004, 03:50 PM   #4
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
I'd rather have more tire than gearing. IFyou can have both, all the betterer.
--kC
Old 04-22-2004, 03:51 PM   #5
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
Hoosier lists the P215/40-16 s04 as TBA. It'll come.... just not out yet.
Can you wait?
Old 04-22-2004, 07:10 PM   #6
motoring
Member#: 49245
1990 Mazda Maita
screaming pumpkin
Mounted on 16x6.5 wheels they are almost exactly the same size.
motoring is offline   Reply With Quote
Old 04-22-2004, 08:46 PM   #7
Scooby Freak
Member#: 40751
'94 SER
Can you wait?
I may have to get the s03 in that size, because that's still available.
Anybody know any contacts at Hoosier that I can ask about that tire?
Old 04-22-2004, 11:21 PM   #8
leecea
Member#: 37359
2003 WRX
I have often wondered how much difference the width makes if you can't get enough neg camber to fully utilize the tire anyway. I wonder if anyone has g-force numbers for varying tire widths on a camber challenged car.
leecea is offline   Reply With Quote
Old 04-22-2004, 11:30 PM   #9
arubus
Member#: 35562
2000 MR2 Spyder
I spoke to the Hoosier rep at Appalacian Tire and inquired about the S04 205-45-16 vs S03 215-40-16.
He said that Hoosier is actually going to make the S04 205-45-16 be wider and have a lower profile so that it will have close to the same dims as the S03 215-40-16. Now this is just what he said that Hoosier is going to try to do, whether that happens or not will be a totally different deal.
FWIW, I'd go with the S04, they've been tested as stickier and more durable, for about the same price as the S03s.
arubus is offline   Reply With Quote
Old 04-23-2004, 09:42 AM   #10
Silver Bullet 02
Member#: 37486
Originally posted by arubus
...FWIW, I'd go with the S04, they've been tested as stickier and more durable, for about the same price as the S03s.
Per Hoosier the S03 and the S04 both use the same compound. The carcus is the only difference. So, the S04 isn't stickier but it does give better traction due to a better carcus.
Old 04-23-2004, 11:56 AM   #11
zoomfactor
Member#: 30440
03 WRX
WR Blue
The real question is are these tires really as addictive as crack?
I'm dying to put a set on my Volks after I get rid of my Azenis.
zoomfactor is offline   Reply With Quote
Old 04-23-2004, 01:08 PM   #12
Silver Bullet 02
Member#: 37486
I really liked the A3S03's in the 215/40/16 size. I decided to go with the 225/50/16 Victoracers this year because they are so much cheaper and will get you within a half second or so of the A3S04's for less than half the price. Half the price because they are about 25% cheaper and they last twice as long as the Hoosiers.
With the A3S04's not coming in the small diameter wide width size it wasn't worth it to me to spend the extra $$.
FS MS: 2 315/35R17 Hoosier A6 and 255/45R17 Hoosier Wets sti752 Wheels/Tires 13 12-10-2007 11:06 PM
Tire question: Hoosier vs. Hoosier vs. ?? Redneck Ricer Motorsports 20 01-30-2004 11:21 AM
205/45 -16 Hoosiers on 7 inch rims? go2svx Brakes, Steering & Suspension 3 06-13-2001 07:31 AM
225 Hoosiers on G-Stock WRX? ConeMasher Brakes, Steering & Suspension 6 04-26-2001 03:54 PM
Se venden 4 hoosiers 205/50 15R Pedro Puerto Rico Impreza Club Forum -- PRSIC 0 04-13-2001 10:05 PM
Message Board Statistics All times are GMT -4. The time now is 08:22 PM.
