Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Notices
Old 08-10-2000, 11:07 PM   #1
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Thumbs up Too much fuel pressure at idle? I have the fix.........finally
As most of you know by now, I have been having problems with my Mazda RX7 twin-turbo fuel pump. The issue is too much fuel pressure at idle. If you are still using OBDII, then you WILL have idle problems.
If anyone out there plans on using the RX7 pump, then be aware of the fact that the stock Sube FPR can't relieve enough fuel pressure back to the tank. You will have about 40 PSI at idle. Ideal is 37 PSI.
I have spent the last three days in junk yards pulling off stock FPRs from every Japanese car I could find. I am now the proud owner of 18 different FPRs. All shapes and sizes. I have cut five of them in half, to see how they are constructed. The problem is that the return orifice is just too small.
Today, while walking through "Pick-A-Part", I spotted a wrecked XT6. You don't see many of those nowdays. I looked at the FPR and it was the exact same style and fit as the one on the 1999 RS. The XT6 engine is a flat 2.7 liter 6 cylinder. I got the FPR and installed it, without any modifications, onto my RS. My fuel pressure at idle went from 40 to 33 PSI!!!! Yeah!!!!!! Thank you Lord!!!
My supercharged/intercooled RS idles PERFECTLY! No more stalling when cold. I have finally solved all the drivability problems with the Rimmer kit and the RX7 fuel pump.
So, if any of you out there are running a WRX, Supra TT, Mazda TT, or Holley high volume pump, this is the answer. Go find yourself a used Subaru XT6 fuel pressure regulator. Or, if you are really anal about used parts, you can order a new one from Subaru for $143.00
The used one cost me $3.00
ARG...the endless pursuit of perfection.
ARG is offline
Old 08-10-2000, 11:13 PM   #2
ARG
Member#: 386
1999 Impreza RS-S
Cool
One more thing! Anyone out there interested in a factory high volume pump for their Sube??? I got the one out of the XT6!!! HA! And guess what, it is a perfect fit for the RS. The pump in the XT6 is the same one for the SVX. The problem is, when is the last time you saw a wrecked SVX?
Anyone like to make me an offer on this factory high volume pump????? If not, it's going into my RS and I will sell the RX7 pump.
ARG....the modification maniac.
ARG is offline
Old 08-10-2000, 11:23 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Thumbs up
Not only do you have way more time on your hands then I do, you use it really wisely. Nice going! Now when I finally nudge myself into FI-land, I'll have the confidence knowing there is someone that has already solved the more major problems. Now if you could only solve the MAP sensor under FI problem...
8Complex is offline
Old 08-11-2000, 04:25 AM   #4
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
ARG ~~ I've been reading about your problems with fuel pressure at idle, but I really didn't have a solution to offer up. I thought other people had been using the RX7 fuel pump without any such problems. I'm using the Supra TT fuel pump and fuel pressure at idle was not a problem with the stock FPR. I added a Bell rising-rate FPR to help get the fuel pressure up to almost 80psi at around 8psi of boost.
Anyhow, glad you got it straightened out. Just find it strange that nobody else has run into this.
SteveS
SteveS is offline
Old 08-11-2000, 07:04 AM   #5
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Cool
ARG -
I'm in the same boat as SteveS. Holley FP, Bell FPR. No problems at idle before the FPR. However, I am running a turbo instead of a supercharger.
PS - Great research info on the XT6, though.
-Paul
Diz is offline
Old 08-11-2000, 07:30 AM   #6
Trey
Member#: 670
Post
ARG - Good info! I've been putting on an independent 1:1 adjustable FPR and just gutting the stock regulator.
8Complex - There's a problem with MY00s and FI? I just finished tuning a MY00 w/ turbo yesterday and we're running 7-8psi with no hickups or stumbles. I monitored everything on our wide-band lambda and all is good. Using the stock ECU w/ MAP too, though a stand-alone would be MUCH better. E-mail me and I'll give you the details.
Cheers,
Trey
CobbTuning.com
Trey is offline
Old 08-11-2000, 09:32 AM   #7
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Post
Great Info ARG. Thanks a lot
Ed.
edekker is offline
Old 08-11-2000, 10:56 AM   #8
Tim Prudence
Member#: 216
Post
What's so bad about having a higher fuel pressure at idle? I've been running my car with 45 psi at idle for several months now... (this is with an adjustable fpr, but I need the extra fuel pressure under boost).
Tim Prudence is offline
Old 08-11-2000, 11:21 AM   #9
ARG
Member#: 386
1999 Impreza RS-S
Post
Tim, are you still OBDII? The ECU senses an over rich condition at idle and tries to cut the injector pulses. (At least on my car) If you are running an AFC or an aftermarket ECU, it most likely won't concern you.
ARG
ARG is offline
Old 08-11-2000, 04:13 PM   #10
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
ARG, according the the SVX FAQ, the pump flows 222lbs/hr. Is the part number from SOA the same between the two? Very interesting to say the least.
Shik is offline
Old 08-11-2000, 06:55 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
I'm interested in the pump. What do you want for it???
Eric
Eric SS is offline
Old 08-12-2000, 12:03 AM   #12
Tim Prudence
Member#: 216
Post
I have an AFC connected to the stock ECU, however, I'm not doing any kind of idle corrections. I played around a little with negative settings at idle, but all it did was cause my idle to die.
Old 08-15-2000, 12:12 AM   #13
Red-Imp
Member#: 1742
2000 Imp 2.5 RS, SRP
& a fast red car ;)
Question
Trey,
Are you using an AFC or something to clamp the MAP voltage within normal limits when it sees boost? Also, how are you handling fuel enrichment on the high end? You said you're using a 1:1 FPR (not rising rate?)
ARG,
I've been drooling over your setup. If Rimmer ever surfaces again (and if my stocks ever go up) I may get that sidewinder. If you have time, would you post a summary of what you've had to do to perfect your SC'd RS? I'm sure I'm not the only one who'd greatly appreciate it.
Thanks,
-Red
Red-Imp is offline
Wearing shoulders off at the track. Too little or too much air pressure? mav1c Tire & Wheel 5 09-26-2005 03:36 PM
How much fuel pressure is too much for STi injectors? wcbjr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-24-2005 09:31 AM
Suddenly, Low Fuel Pressure at idle?? IowaRS Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-02-2005 06:32 PM
What is everyones fuel pressure at idle and what pump/FPR are you using? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-30-2002 02:32 AM
fuel pressure at idle spiralsmurf Normally Aspirated Powertrain 0 04-07-2002 12:53 PM
