Old 04-22-2004, 07:01 PM   #1
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Default Intake Manifold
The intake manifold on the newer RS, 02-04, possibly earlier models top, it is a plasitc composite or something to that nature. I was suprised and thinking what the heck was Subaru thinking . There probably is a reason for it that I don't know about. But anyway, I want to turbo my car in about 2 years and I was wondering what you older subi RS do? Do you switch out the manifold for a WRX or have a fabricated one that will have all the sensors and components? I know that the manifold is kinda crappie with anything above 250 hp. Detailed info would be most appreciated. Thanks
impr25rs is offline   Reply With Quote
Old 04-22-2004, 07:08 PM   #2
03rsturbo
Member#: 26164
2005 Legacy GT
I'm not quiet sure what you are talking about but I have a 03 rs turbo and I can assure you of one thing, the intake manifold is aluminium and can handle far more psi then the rest of the block
03rsturbo is offline   Reply With Quote
Old 04-22-2004, 07:22 PM   #3
impr25rs
Member#: 60162
04 Aspen RS
That was a quick reply. Thanks. I am serious. It is not a metal intake manifold. I swear it is a plastic composite or something. Maybe it is aluminum with a plastic coating or something. I have another question. If I get borla headers (or something beter) will an upipe bolt on with a WRX crossmember?
Old 04-22-2004, 09:33 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Didn't I already answer this manifold question on WRXforum? I guess I am not a very trusted source on such things.
As for the Borla headers; if you use them, you will want an uppipe designed for an RS-T, and to forget about the crossmember, especially since a stock up-pipe will hit your SOHC heads anyways...
Old 04-22-2004, 10:47 PM   #5
Aphex
Member#: 146
'16 WRX Limited
I've certainly never heard any such info about the intake manifold, I've never seen anybody complain about the intake manifold. and it most certainly is not plastic.
the only issues people have is if they try to fit a wrx intercooler to the manifold, it tends to be a little tight in the firewall area, but nothing beyond that.
Aphex is offline   Reply With Quote
Old 04-22-2004, 10:51 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
The composite manifold is on all of the '04 EJ25's. A search in the NA forum will answer any other questions for all of you...
Old 04-22-2004, 10:55 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Your manifold is plastic. It's also lighter, doesn't soak up heat as much and flows a little better than the previous version. You can swap out to an aluminum manifold from a SOHC EJ2.5 if you want to make sure you don't run into troubles from turbo heat.
Some savvy N/A folks may want to swap with you to reap the bennies for autocross.
Ask zzyzx about the differences and how well they work.
Jay Storm
www.sourcemotorsports.com
Old 04-23-2004, 12:36 AM   #8
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
A plastic manifold wouldn't be bad for a turbo. (I've personally seen at least 15lbs on a Toyota plastic manifold) If you tested it, I bet it would hold 50-100psi just fine. Also, bet that manifold will stand up just fine to heat. As long as the throttle body is in the same place as it has been in previous years, just go for it and don't worry about it.
-Charlie
phattyduck is offline   Reply With Quote
Old 04-23-2004, 01:20 AM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
For a turbo kit, I would make sure the turbo is strongly supported and not hanging off the intake manifold in any way shape or form. Otherwise, from what I hear, should be fine for turboing. Alot of the new JDM turbo engines have the plastic intake manifolds.
Old 04-23-2004, 01:54 AM   #10
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Is it just me but do plastic manifolds sound .... like subaru cheapen yet again...
i'm still in shock that its plastic...
HOK is offline   Reply With Quote
Old 04-23-2004, 02:41 AM   #11
phattyduck
Member#: 32955
'03 WRX Wagon
Hmmm... lets see: Its lighter, easier to form, conducts less heat, faster to make, cheaper... what's wrong with plastic? I thought it was weird at first... but it seems like a fine idea to me.
-Charlie
Old 04-23-2004, 02:43 AM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
hey man if u wanna trade me for my metal one ill gladly do it
lemme know
alex
Old 04-23-2004, 02:47 AM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
WHAT is going on???
you guys want plastic turbo housings too? maybe i'm just too old school...
now a CF intake mani... hehe
Old 04-23-2004, 02:05 PM   #14
impr25rs
Member#: 60162
04 Aspen RS
Hey Matt, I didn't mean anything by asking the question here. I value all the input I get and I do believe what you say. You told me to come here and ask the question to get more info. Sorry man. Anyway, I guess I will have to think about the manifold. I may stick with it or not. I was just suprised by this and wondered if any other models had this or if it was new. And new it is. Thanks for the input I will take up some consideration. White 2.5rs will think about it. Thanks guys
Old 04-23-2004, 02:25 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
impr25rs,
My short term memory isn't what it used to be. I was just giving you some shizy, but had completely forgotten that I actually suggested you come over here and inquire some more.
And I still have that STi manifold if you are interested...
Old 04-25-2004, 01:38 PM   #16
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
It probbaly cost Subaru alot more money to develope a plastic manifold rather than keep using the aluminum one.
LVSUBARU is offline   Reply With Quote
Old 04-25-2004, 01:42 PM   #17
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
thats debatable...
Does the STI have this plastic intake manidold? If not then i would question the benefits and cost that you guys mention...
Old 04-26-2004, 03:09 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
...and in SOA's eyes, the intended use between an STi and say, an Outback would be a little different, no? Low production volume, 14psi and marketed hi performance abilities versus high production, everyday use by Jane Q. Public......
thats debatable...
Jay Storm
There's a fine line between "hobby" and "mental illness".
Old 04-26-2004, 03:33 PM   #19
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
i don't get what your trying to say here?
i'm trying to say that if this intake manifold was better and is more expensive, why would they not put it in the STI or WRX.
Old 04-26-2004, 05:21 PM   #20
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
as for the "older" cars the intake isn't bad! if you want some sick HP numbers the intake isn't going to help that much. you can get the intake extrude honed but your better off just port matching everything. but your best dollar for dollar hp is getting the heads ported and polished! Jeff
jeff22 is offline   Reply With Quote
04sti intake manifold vs. 06 wrx intake manifold? jpvtec1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-07-2007 06:26 PM
USDM STi intake manifold to Spec C intake manifold caveats? Dasani Built Motor Discussion 2 02-08-2007 11:01 PM
WRX intake manifold vs. STI intake manifold AugustusMaximus Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-29-2006 11:00 PM
STi (Red) Intake Manifold verses USDM (Silver) Intake Manifold Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-25-2002 04:11 PM
MY98 Intake Manifold comparison to MY99-01 Intake Manifold latinskllz Normally Aspirated Powertrain 0 05-18-2002 02:50 PM
