Old 04-23-2004, 09:13 AM   #1
zoomfactor
Member#: 30440
03 WRX
WR Blue
Question Base Camber for Auto-X cars also street driven?
For those of you with camber plates/coilovers. What did you set as the "zero" camber. In other words with your camber plates on the center what is your static camber? Recommendations/Advice?
I've got the Tein RA's set at Tein's recommended ride height. With the camber plates at zero I've got about 2.5 degrees negative. This seems to be a bit much on the street.
Thanks,
JD
zoomfactor is offline   Reply With Quote
Old 04-23-2004, 01:26 PM   #2
PaulC
Member#: 12283
How do you figure it's a "bit much"? Are you getting abnormal tire wear? Darty steering or instability under braking?
FWIW toe settings have a much more drastic effect on tire wear, especially for daily driving. For instance, when I had 1* of neg camber on my car and 1/4" of toe out, I had horrendous wear on the inside shoulder of my front tires. Now with 2.8* neg camber and zero toe I get great wear, and more importantly, great wear at events.
my $.02
PaulC is offline   Reply With Quote
Old 04-23-2004, 01:57 PM   #3
zoomfactor
Member#: 30440
03 WRX
WR Blue
Just the usual tire wear - slight bias towards the inside -- really no big deal. A little dartiness due to tramlining Azenis in street work zones -- again no big deal.
I was curious what people used as their "base" camber setting, before "tweaking" camber at events.
Old 04-23-2004, 01:58 PM   #4
jmott
Member#: 6713
2007 Prius
brown
-2.5 usually works out ok if you do a lot of city driving, take corners pretty hard, and run 0 toe.
tweaking camber at the event can be problematic, since it will also change the toe.
I think on the WRX/STI the toe goes more out as you add camber, which may work out ok in the front. 0 toe for the street and slight outward toe for autocrossing is probably what you want anyway.
jmott is offline   Reply With Quote
Old 04-23-2004, 02:08 PM   #5
KC
Member#: 442
13 Crosstrek XV
00 S2000
Yes, yes it does.
I had my Camberplates set to 'street' and we adjusted toe and was like great, 1/8 toe out. Then I saw that the camber was not in the right spot....
We maxed the camber, and it turned to about 3/4" toe out.
Doh!
--kC
I now have toe plates and camber gauge...
KC is online now   Reply With Quote
Old 04-23-2004, 04:37 PM   #6
zoomfactor
Member#: 30440
03 WRX
WR Blue
Ahhh so this is the secret alignment and the secret to rotational nirvana!
BTW what camber gauge are you using?
Old 05-09-2004, 09:12 AM   #7
jcroy66
Member#: 42675
2003 WRX #177 STX
www.TeamSoloRacer.com
And where did you get it and the toe plates?
jcroy66 is offline   Reply With Quote
To shave or not to shave? Direzza Star Specs for auto-x (STX) and street use thereplacement Autocross 28 03-03-2009 03:03 PM
Aftermarket ECU in NJ street driven cars G.Subramaniam Tri-State Area Forum 5 09-16-2006 07:07 PM
Best camber settings for Auto-x/street? HIHO Legacy Forum 9 01-21-2003 09:43 PM
Nutty rear camber for Auto-x? Kostamojen Brakes, Steering & Suspension 23 08-26-2002 01:00 AM
How good is a DMS 50MM setup for a primarily street driven car? Overkill? Digital_Boy Brakes, Steering & Suspension 13 04-14-2001 04:44 PM
