Mid Atlantic Impreza Club
Old 04-23-2004, 09:24 AM   #1
AKGC8
Member#: 1305
2000 Impreza
Default Electronics supply stores? I need a resistor.
Hey, does anyone know of a good electronics supply store is in the DC area. I need a 3 or 3.3 ohm resistor to get rid of the airbag light for my Ver 3 steering wheel. Radio Shack doesn't have them. Thanks
AKGC8 is offline   Reply With Quote
Old 04-23-2004, 09:51 AM   #2
LotusDriftx
Member#: 48528
Default some sites Ive used
http://www.newark.com/
http://www.alliedelec.com/
http://www.digikey.com/
and http://www.radioshack.com/category.a...4%5F000&Page=1
You could use 3 x 10 ohms in parallel = 3.33 ohm. Thats your best bet for simplicities sake as I'm guessing your local radio shack would have that in stock.
What do you need a 3.3 ohm resistor for? Just curious.
LotusDriftx is offline   Reply With Quote
Old 04-23-2004, 10:38 AM   #3
bluestone
Member#: 36583
2004 WRX sedan
assuming this is the same one used for seat airbags, i have a couple. pm me your address and i'll send you one unless you want to pick it up. i'm in NoVa right now.
bluestone is offline   Reply With Quote
Old 04-23-2004, 10:43 AM   #4
AKGC8
Member#: 1305
2000 Impreza
I thought the actual resistance of the airbag was 3.3 ohm. 3 ohm resistors were just more common and close enough that they work. So I was just saying I wanted to find either a 3 ohm or 3.3 ohm resistor. I may be wrong.
Old 04-23-2004, 10:51 AM   #5
AKGC8
Member#: 1305
2000 Impreza
Where are you in NOVA and how long will you be around? I could probably meet up, thanks.
Old 04-23-2004, 11:06 AM   #6
LotusDriftx
Member#: 48528
Just twist three 10ohms together.
Old 04-23-2004, 11:08 AM   #7
AKGC8
Member#: 1305
2000 Impreza
Doesn't 3 10 ohm's in series = 30 ohms?
Old 04-23-2004, 11:11 AM   #8
bluestone
Member#: 36583
2004 WRX sedan
3 10's in parallel as he said above
emailed you
Old 04-23-2004, 11:11 AM   #9
LotusDriftx
Member#: 48528
Connect them like that, twist or solder or whatever the ends. That is parallel.
Yes in series it would be 30 ohms
Old 04-23-2004, 11:19 AM   #10
AKGC8
Member#: 1305
2000 Impreza
for some reason I thought you were saying series.
Old 04-23-2004, 11:20 AM   #11
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I bought some for my seat swap to shut up the airbag light, but won't be back til Sunday. I have a ton of extras since the smallest amount you can buy is like 50. So if everything else falls through let me know.
john
Old 04-23-2004, 11:48 AM   #12
AKGC8
Member#: 1305
2000 Impreza
Thanks guys. I may just try the 10 ohms in parallel since I can get them tonight. I've got a trashed airbag connector that I can cut up and solder the resistors in.
Old 04-23-2004, 03:30 PM   #13
xenonk
Member#: 18823
2011 with 4 wheels
monochrome?
next question: how are you going to wire up the resistors to the harness? Are you just going to cram it into the harness? btw, which two wires or single wire that you tap the resistors to?
Keefe
xenonk is offline   Reply With Quote
Old 04-23-2004, 03:34 PM   #14
AKGC8
Member#: 1305
2000 Impreza
Well with my 1999 L, I've got a trashed airbag harness(the part that goes through into the steering wheel). I've cut the airbag connector off and will just splice the resistor between the two wires. There is a yellow/blue and yellow/black wire. I've heard you can just push the resistors right into the airbag connector.
Old 04-24-2004, 07:10 PM   #15
Butt Dyno
Member#: 17301
is the "dark side"
I just pushed the resistor into the clip and electrical taped it... has worked totally fine
john
Old 04-24-2004, 08:24 PM   #16
AKGC8
Member#: 1305
2000 Impreza
I tried the 3 10ohm resistors in parallel and it's working.
Is the airbag light supposed to stay on for a few seconds after you start the car and then go out? I've been driving with the airbag light for so long that I have forgotten how it worked stock. Eh, I guess it doesn't really matter either way.
Old 04-25-2004, 12:57 AM   #17
bluestone
Member#: 36583
2004 WRX sedan
john
same for me. light came back on twice, but nothing that a little jiggle didn't fix. the ends might have gotten pushed together before i had the tape on.
glad you got it fixed.
anyone else out there need a 3.3 ohm just let me know.
Electrical Supplies Store STIRS Mid West Subaru Owners Club Forum -- MWSOC 2 05-25-2006 02:25 PM
Welding supply stores?? norexyet Tri-State Area Forum 7 10-31-2005 08:39 AM
anybody in HOU work at electronics store,...I need a new TV glilly Texas Impreza Club Forum -- TXIC 33 03-26-2005 03:40 AM
Art Supply Stores in the South LA Area sherifx Southern California Impreza Club Forum -- SCIC 13 02-05-2005 01:08 AM
Are there any premier auto supply stores in Atlanta? DanMan South East Region Forum 5 03-25-2002 08:54 PM
