Old 04-23-2004, 11:40 AM   #1
speedway7414
Member#: 60253
Question Service Bulletin WWP-99: Coolant Conditioner Additive = Head Gasket leak??
Head gasket problem?
See:
http://forums.nasioc.com/forums/show...nt+conditioner
A month ago, my Suby started running really hot. I checked the antifreeze levels and ended up pouring 3/4 gallon into the radiator- a lot.
Recently, I received this Service Bulletin for a conditioner to be added to the coolant system to avoid head gasket leaks.
Since I believe my head gasket has already been leaking, I am concerned that only adding a conditioner is a band aid measure. I do not want to have the problem resurface once I am out of warranty, or have this existing leak reduce the long term reliability. My 2000 Suby has 48k on it, and I have an extended warranty to 100k or 2006. I expect to get 200k+ miles out of the engine.
*** Any experts out there willing to offer some advice/insight on importance of getting the gasket replaced, and ideas on how to negotiate this?
Thank you in advance for you assistance
speedway7414 is offline   Reply With Quote
Old 04-23-2004, 02:20 PM   #2
wayoutwest
Member#: 14379
2007 Acura
gray
Bump for this too ... I've had to top off my resovior a couple times and I have 4000 miles left on the warranty.
wayoutwest is offline   Reply With Quote
Old 04-23-2004, 02:23 PM   #3
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Adding conditioner to an already leaking head gasket isn't going to fix the leak.
If your head gasket really is leaking, you need to bring the car in and make them fix it.
heffergm is offline   Reply With Quote
Old 04-23-2004, 02:32 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Actually, you are quite mistaken. It does fix many of the leaks, but just external ones.
Brian
Old 04-23-2004, 05:14 PM   #5
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Impreza GC8 warranty?
I don't understand: if your car is still under warranty, why don't you just take it to the local dealer and have it fixed?
Coolant conditioner is a prophylactic measure. It's not going to fix an existing problem. If your head gasket is leaking, you need to get it replaced before you fry your engine.
vvk is offline   Reply With Quote
Old 04-25-2004, 01:58 AM   #6
MCGOO
Member#: 47874
2015 Impreza
Deep Blue
The rules state that the dealer adds the conditioner, even to an engine that is seeping (not gushing). If it continues to leak it needs gaskets.
If you are out of warranty & your dealer says not covered, call Suabru head office & ask for assistance (don't demand it), & they just might help you.
No promises
McGoo
MCGOO is offline   Reply With Quote
Old 04-25-2004, 03:01 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
key is to get the "fix" done while under warranty. Make sure the service ticket mentions that you already have a leak.
Then, if it continues/gets worse, it is documented while under warranty.
Old 04-29-2004, 05:08 AM   #8
speedway7414
Member#: 60253
Appreciate all your comments!
for more see http://forums.nasioc.com/forums/show...5&pagenumber=1
Old 04-29-2004, 04:00 PM   #9
NRTmotorsports
Member#: 16517
'13 BRZ
I am a technician at Subaru and if a car is under warranty the conditioner is added and the leaks continue Subaru will replace the head gaskets under warranty. I have an interesting tech. bulletin I will try to find and post for you.
NRTmotorsports is offline   Reply With Quote
Old 04-29-2004, 04:04 PM   #10
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I've read it's mostly the EJ25 models, but has it ever happened to any WRXs?
[i just put a bottle of subaru coolant conditioner (little 125mL blue bottle)in my radiator yesterday, but i'm not sure if it's the same stuff as mentioned above...]
Old 04-29-2004, 10:31 PM   #11
NRTmotorsports
Member#: 16517
'13 BRZ
The recall is only on the EJ25 not on the WRX or any other models, just the naturally aspirated 2.5. As for the conditioner its just a little bottle of "stop leak", nothing special, im sure you could even go into the parts department at a dealer and by one for a couple bucks, but why do that when the recall pays for it, but like many other people besides me, I dont like other people working on my car.
Old 04-30-2004, 08:08 PM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya, I got this notice about 2 months after I did my head gaskets. Oh well, I got it fixed and it cost me 50 bucks. Also gave me the opportunity to drop in a new clutch and my lightened flywheel.
Tim Sanderson is offline   Reply With Quote
Old 05-11-2004, 11:15 AM   #13
speedway7414
Member#: 60253
I do look forward to any related Tech Bullentin you may be able to dig up!
Head Gasket leaking coolant credekop Warranty Issues & SOA Problems 12 08-08-2009 03:17 AM
Engine coolant... possible blown head gasket? WRX_REED Normally Aspirated Powertrain 2 05-07-2005 08:28 PM
Service Program Bulletin WWP-99: Engine Cooling System Conditioner speedway7414 Warranty Issues & SOA Problems 2 04-24-2004 01:35 PM
Service Bulletin WWP-99: Coolant Conditioner Additive = Head Gasket leak?? speedway7414 Normally Aspirated Powertrain 2 04-23-2004 04:59 PM
Both Head Gaskets leaking on a 2001 :( 2001LegactGT Legacy Forum 7 05-26-2002 12:39 PM
