#1 |
Vendor
Vendor Sales Rating: (1)
Member#: 12262
The same great quality that the name Ecutek has delivered from the start...
Ecutek dash monitors in stock now. ![]() Radio single DIN mount $735 Dash pod mount $750 In addition to standard diagnostic functions, such as ECU reset and fault code display, several features are included such as the facility for water injection control control. The unit incorporates display of many ECU parameters, such as boost pressure & RPM, and has user adjustable alarm and data recording facilities. Additional sensors can be added to display exhaust gas temperature and oil pressure for example. The monitor reads its information directly from external sensors as well as direct from the ECU via the vehicle diagnostics port. The high data rate allows the display to be updated approximately five times every second. The parameters displayed on each screen are customisable and allows the user to tailor the display to their personal preferences. The unit also records peak values of parameters such as RPM & boost pressure. The user can set their own alarm limits which when are exceeded, can turn on an external warning lamp. Information is displayed on a 2 line by 24-character display and is controlled by 4 buttons. The unit does not interfere with the operation of the vehicle in any way, though since the vehicle only has one diagnostics port, DeltaDash obviously cannot be used at the same time ! If the ECU has been programmed with the Map Switching / User Tuning functionality then the display will make available the following extra features: Map switching may be controlled from and displayed by the dashboard display. User Tune parameters may be adjusted. i.e. Parameters such as ignition, fuel, boost, VVT, rev limit and idle speed can all be adjusted if the ECU has been suitably configured. This dashboard display uses a high brightness vacuum fluorescent display - many times brighter and clearer than LCD variants, at any viewing angle too. Buy it here or see more photos. |
#2 |
Member Sales Rating: (89)
Member#: 7958
Vehicle:09 GH B+ |
Nice looking moniter- couple of questions. Is he OBDII port moved or plugged into at the normal under dash spot? Just unplug this unit to log?
How many parameters can you moniter at the same time w/ this unit? I've seen folks "make up" their own gauges w/ delta dash- a bank of traditional looking round gauges- can this be accomplished w/ this unit? How may remote sensors can be picked up by this unit? I was thinking egt and oil temp (the ecu already gives water temp). Also will a wide band be compatible w/ this unit? Sorry for all the questions, but this might be just what I was looking for. Thanks Big Sky |
#3 | ||||
Vendor
Member#: 12262
You can do it either way. Quote:
Big Sky [/quote] |
