Old 04-23-2004, 12:30 PM   #1
soobyfan
Member#: 31803
2002 VW GTI 1.8T
matchstick red
Default water in intake! how to keep water out - let air in
so I have had my 2 hood vent and the scoop gaurds removed almost immeadiately after i received my RS but recently with alot of rain the intake has been getting water in it. I reattatched the gaurd over the intake today to fix the problem but i was wondering what my other options are to getting cold air into the engine bay around the cone filter.
I have a AEM short ram intake with K&N cone filter
can i get a bypass valve and then remove the vent gaurd again or will i have to cut the intake in half?
I was thinking of maybe routing some ducting from underneather the turn signal up to the cone filter....?
also do i need to replace anything for installing aftermarket cams on a 2000 rs 85k miles ? and what is the best BIG cam for lots of power
soobyfan is offline   Reply With Quote
Old 04-23-2004, 02:59 PM   #2
piker28
Member#: 22664
this doesnt make much sense, why did you remove the shield if there is no intake there? the aem sticks over by the fenderhole doesnt it? by removing those shields you really arent getting anymore airflow to the engine could be even making more drag i think
piker28 is offline   Reply With Quote
Old 04-23-2004, 03:55 PM   #3
Supraru
Member#: 23313
99' 2.5Rs
black
I do the same thing only my intake sits right under the vent. I'm sure it really doesn't do anything but I'm sure it cools the motor better and the intake is louder. When I know it's gonna rain I put only the one on that protects me from blowing a maf sensor. Next time just watch the weather and you'll be fine, make sure when it starts to rain you put it on.
Supraru is offline   Reply With Quote
Old 04-24-2004, 09:07 AM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
a bypass valve isnt going to do anything..if the intake is getting alittle wet dont worry about it.its not going to do anything.
I havent had my vents on my car since I bought it and I drive in all sorts of weather.
with the vents off it relieves negative pressure in the engine compartment, whe you are driving the air flow comes into the engine bay and has no where to go , with the vents out, that airflow goes right out the top.
sidewayz is offline   Reply With Quote
Old 05-07-2004, 11:29 PM   #5
1fastrs
Member#: 60522
I have a K&N Airfilter on my car the day I bought it. I opened up both airvents and the hood scoop. Didn't really notice a big change, but I am now hearing a whirling sound after 3,000RPM's. As the RPM's get higher, the sound gets louder. I tell my friends that they are hearing my turbo . I put one of the airvents that covered the battery back on so it does not get wet, and cause damages. That was a smart move when living in Washington.
I got this shield that blocks water from entering from the top, but not from below the car. I can take a picture to show you what I mean.
1fastrs is offline   Reply With Quote
How to keep toilet bowl full to rim with water? ryan2l Off-Topic 81 11-21-2006 11:42 AM
How NOT to keep yourself out of suspicion sonicblue Off-Topic 7 12-15-2005 01:03 PM
how to keep a fire alive in water MyScoobie28 Off-Topic 7 12-04-2005 08:42 PM
how to get water out of my jdm gc8 tails? legacy2003 Electrical & Lighting 5 09-27-2004 11:49 AM
how to make a true cold air intake subyguy1995 Normally Aspirated Powertrain 2 08-14-2002 02:35 AM
